Rayan Posted February 9, 2019 Report Share Posted February 9, 2019 Hi all, I am thinking of purchasing a second generation Ford Edge. What are some of the issues you all have faced with your Edges? Thanks! Quote Link to comment Share on other sites More sharing options...
SUV-E Posted February 9, 2019 Report Share Posted February 9, 2019 ?Wanting to drive it all the time... 2 Quote Link to comment Share on other sites More sharing options...
anile_eight Posted March 28, 2019 Report Share Posted March 28, 2019 It depends on what year as some early one issue (leaking and very sensitive brakes) were (mostly) fixed after year 1 as an example. 1 Quote Link to comment Share on other sites More sharing options...
Rayan Posted April 4, 2019 Author Report Share Posted April 4, 2019 Thank you all for your input! I picked up a 2015 Edge Sport and love it! As mentioned the brakes are quite sensitive on it and the power fold button and power outlet in the trunk do not work. 1 Quote Link to comment Share on other sites More sharing options...
Perblue Posted April 4, 2019 Report Share Posted April 4, 2019 46 minutes ago, Rayan said: Thank you all for your input! I picked up a 2015 Edge Sport and love it! As mentioned the brakes are quite sensitive on it and the power fold button and power outlet in the trunk do not work. The power plug in the back seat probably doesn't work also. Atleast that's how it was in my 13 when my trunk one fried both times. Quote Link to comment Share on other sites More sharing options...
Rayan Posted April 23, 2019 Author Report Share Posted April 23, 2019 You are correct, my power plug does not work either! How did you fix it? Quote Link to comment Share on other sites More sharing options...
Perblue Posted April 23, 2019 Report Share Posted April 23, 2019 I had warranty so I just took it in and had them do it. I unfortunately don't recall what they did but I know it wasn't a fuse. I'll see if I still have the repair sheet around. Quote Link to comment Share on other sites More sharing options...
anile_eight Posted December 12, 2019 Report Share Posted December 12, 2019 We have a 2015 and really it was all cosmetic things that were taken care of under warranty. We purchased ours in late October after the water intrusion was fixed. We also had the brake booster replaced under warranty (under the TSB) for sensitivity. No mechanical issues to speak of plenty happy. Wish we had sync 3 is all which came in 2016 and newer. 2 Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted December 12, 2019 Report Share Posted December 12, 2019 I believe TxFordOwner (sp?) has kits available for you to upgrade to Sync3. Quote Link to comment Share on other sites More sharing options...
anile_eight Posted December 12, 2019 Report Share Posted December 12, 2019 2 minutes ago, WWWPerfA_ZN0W said: I believe TxFordOwner (sp?) has kits available for you to upgrade to Sync3. I have seen a couple around I believe but they’ve all been rather expensive around $1,000 which right now is not worth it. 1 Quote Link to comment Share on other sites More sharing options...
Gadgetjq Posted December 12, 2019 Report Share Posted December 12, 2019 (edited) On 4/23/2019 at 11:47 AM, Rayan said: You are correct, my power plug does not work either! How did you fix it? Whoops, just noticed this post was from April this year. Just a guess you've already sorted that problem out. For anyone else who might have this problem check the fuse first. Getting to it may be a challenge. Check your owner's manual to determine the location (number) of the power point fuse. Remove the drawer on the dash to the left of the steering wheel. To do that open the drawer then, with palm up, reach into the drawer opening and pull straight back on the top of the housing (not the drawer itself). You'll hear a click and the entire assembly will come free. Now you can look through that opening at the fuse box. Reach up under the dash to extract and replace fuses. Note: the 2nd gen Edge uses micro blade fuses. Edited December 12, 2019 by Gadgetjq 2 Quote Link to comment Share on other sites More sharing options...
Rayan Posted December 19, 2019 Author Report Share Posted December 19, 2019 On 12/12/2019 at 11:49 AM, Gadgetjq said: Whoops, just noticed this post was from April this year. Just a guess you've already sorted that problem out. For anyone else who might have this problem check the fuse first. Getting to it may be a challenge. Check your owner's manual to determine the location (number) of the power point fuse. Remove the drawer on the dash to the left of the steering wheel. To do that open the drawer then, with palm up, reach into the drawer opening and pull straight back on the top of the housing (not the drawer itself). You'll hear a click and the entire assembly will come free. Now you can look through that opening at the fuse box. Reach up under the dash to extract and replace fuses. Note: the 2nd gen Edge uses micro blade fuses. Great thing to check, mine ended up being that somehow the wiring harness to the power outlet and buttons for the seat had become unplugged behind the trim. Weird because the car has never been in a accident, but it is all fixed now! 1 Quote Link to comment Share on other sites More sharing options...
