Stevekh Posted February 7, 2019 Report Share Posted February 7, 2019 I just purchased 2015 for edge 2.0 eco-and I’m getting 19.5 mpg. The rating on it is 21 mpg to 30 mpg with average 24.5 MPG. Any suggestions on why I’m getting this gas mileage I live in California and I use my car mainly on highway. Please advise! Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted February 7, 2019 Report Share Posted February 7, 2019 Any start and stop driving? How about idling, kills mileage. I would suggest filling up at the pump, allowing the pump to just shut off (no topping off). Record your mileage and when 3/4 low, fill at the same pump (if possible). Subtract previous mileage from current and divide by number of gallons. Gives a more accurate reading of mpg. If its still low, check your tire air pressure (keep at whats printed on door sticker). If OK, try cleaning the MAF (mass airflow sensor). If the wire becomes dirty, it can definitely affect milage. How many miles on car? 3 Quote Link to comment Share on other sites More sharing options...
benoborich Posted February 8, 2019 Report Share Posted February 8, 2019 1 hour ago, Stevekh said: I just purchased 2015 for edge 2.0 eco-and I’m getting 19.5 mpg. The rating on it is 21 mpg to 30 mpg with average 24.5 MPG. Any suggestions on why I’m getting this gas mileage I live in California and I use my car mainly on highway. Please advise! Quote Link to comment Share on other sites More sharing options...
benoborich Posted February 8, 2019 Report Share Posted February 8, 2019 I have the same vehicle. If I am travelling around 60mph with little or no headwind I get around 26 to 27mpg. At 70 or 80mph with a headwind it will drop to around 21 or 22 mpg. With a strong headwind it can drop to 20 or lower. Not sure why you would get less. Quote Link to comment Share on other sites More sharing options...
lildisco Posted February 8, 2019 Report Share Posted February 8, 2019 (edited) All gas isn't created equal. Look for top tier gas stations. Make sure your current on oil changes. How many miles are on the car? If higher, closer to 100,000,id change your plugs. Actually, I'd change them out anyways because you don't know how the other person drove. Another thing would be to try resetting the ecu. Just disconnect the negative battery cable for about 10 minutes. Hook it up then let it idle for a few minutes & then drive like normal. The ecu is a learning ecu. If it hasn't been reset since you bought it, it probably has thousands of miles learned from the previous owner(s). Once it learns your driving style, shift points, etc., you should she a few more mpg's. Especially if you're all highway & drive UNDER 70 - 75 mph. Biggest thing is driving style. Medium to hard accelerations are going to be in boost. Boost = more fuel = bag mpg's. Crusing above 70-75 is going to be in boost. But if you cover the basics as i said or stated above, you should see some sort of improvement Edited February 8, 2019 by lildisco Quote Link to comment Share on other sites More sharing options...
omar302 Posted February 8, 2019 Report Share Posted February 8, 2019 My experience is that engine idling will have a big effect on fuel economy. Warming up, traffic jams and remote starting regularly will decrease the average fuel economy significantly. Quote Link to comment Share on other sites More sharing options...
Stevekh Posted February 8, 2019 Author Report Share Posted February 8, 2019 The car only driven 31k Quote Link to comment Share on other sites More sharing options...
Stevekh Posted February 8, 2019 Author Report Share Posted February 8, 2019 3 hours ago, lildisco said: All gas isn't created equal. Look for top tier gas stations. Make sure your current on oil changes. How many miles are on the car? If higher, closer to 100,000,id change your plugs. Actually, I'd change them out anyways because you don't know how the other person drove. Another thing would be to try resetting the ecu. Just disconnect the negative battery cable for about 10 minutes. Hook it up then let it idle for a few minutes & then drive like normal. The ecu is a learning ecu. If it hasn't been reset since you bought it, it probably has thousands of miles learned from the previous owner(s). Once it learns your driving style, shift points, etc., you should she a few more mpg's. Especially if you're all highway & drive UNDER 70 - 75 mph. Biggest thing is driving style. Medium to hard accelerations are going to be in boost. Boost = more fuel = bag mpg's. Crusing above 70-75 is going to be in boost. But if you cover the basics as i said or stated above, you should see some sort of improvement The car is driven 31k only Quote Link to comment Share on other sites More sharing options...
TheWizard Posted February 8, 2019 Report Share Posted February 8, 2019 I found that it was quite difficult to achieve the rated mileage because the endless torque of the EcoBoost makes it hard not to keep putting your foot in it. We frequently had mileage similar to what you're getting but found that if you're conscious of how hard you press the go pedal, you can see a marked improvement. Also remember that winter blend gas has less energy than summer blend so you will get worse mileage from that alone. There are many other factors that cause winter mileage to be worse than in warmer weather but most of those won't impact you in California as much as they do in colder climates... still, it's something to keep in mind. Quote Link to comment Share on other sites More sharing options...
