Edge ST in Kentucky
gcotton30
I assume you are talking about the springs. Be sure the springs are right side up and are sitting in the cups properly . There are no spacers used with H&R springs that I am aware of .The rear of the car should be even right to left . If that is what you referred to. Did you look at the H&R Spring install threads we have here at the Forum?  There are some good tips and tricks to insure proper fitment of the springs and ease the install .We also recommend a new alignment with the springs. Align it after the springs have set in. It takes a few miles and some time for them to set, then align the car . I have posted alignment specs as have others for G2 Edge Sports with H&R springs. The specs are different than stock this is to adjust for the new ride height.
