Knocking
Johnnie007
It is not at all unusual for an engine to knock occasionally under loads such as towing, steep grades, or high ambient temperatures but the knocking would be light and intermittent.  If you experience knocking during normal driving conditions then something is wrong.  The first step would be to fill up at a different gas station - preferably a Top Tier or at least name brand station.  It could be that you're just getting bad fuel.  If the knocking persists you should have it checked by the dealer or a trusted mechanic (the guy who told you that new cars knock should not be that trusted mechanic).  You can run higher octane fuel in the meantime to reduce knocking (higher octane fuel is not "better" but it is more resistant to knocking).
There are different kinds of "knock".
Knock, as in mechanical knock from excessive engine clearances (PTW, crank and/or rod bearings).
Preignition or detonation knock. Could be caused by low octane fuel, massive piston crown carbon build up, etc.
Tappet noise from the valvetrain.
Which is it?
