Redneckbuckeye Posted January 27, 2019 Report Share Posted January 27, 2019 I have a 2011 ford edge se and am having an issue. The rear lift gate adjar chime goes off intermittently while driving. Going over a bump almost always triggers the alarm and interior lights. Looked around the internet but could not find anything on this issue specifically. Thanks for any help. Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted January 27, 2019 Report Share Posted January 27, 2019 Sounds like a loose or intermittent connection to me. I would check the latch, see if it is dirty or rusty, clean it up, liberally apply dielectric grease and see if that is good enough to resolve the situation. If not, then you will likely need to remove the hatch quarter paneling for inspection, and verify that the battery has good cold cranking amps (CCAs). 1 Quote Link to comment Share on other sites More sharing options...
