SSM 47581 - U3000:47 DTC set in the ABS module
omar302
SSM 47581
Some 2019 Edge and Nautilus vehicles may have a U3000:47 DTC set in the ABS module, with no other mechanical symptoms related to this DTC. This DTC may have been inadvertently set at the factory and it has no functional effect on the vehicle. The DTC will permanently clear after 96 key cycles when the vehicle is driven over 20 km/h (13 mph), and no further action or repair is necessary.
Source.
