TSB 17-2271 2.0L/2.3L/2.7L EcoBoost, 5.0L, 5.2L – Engine Oil Pressure (EOP) Sensor Oil Leak
22 December 2017
This bulletin supersedes 15-0183. Reason for update: Missing or Incorrect Applications
Model:
Ford
2015-2017 Edge
2015-2017 F-150
2015-2017 Mustang
2016-2017 Mustang
2016-2017 Explorer
2017 Escape
Lincoln
2017 MKC
Summary
This article supersedes TSB 15-0183 to update the vehicle list and vehicle model years.
Issue: Some 2015-2017 Edge vehicles equipped with a 2.0L/2.7L EcoBoost engine, 2015-2017 F150 vehicles equipped with a 2.7L EcoBoost or 5.0L engine, 2015-2017 Mustang vehicles equipped with a 2.3L EcoBoost, 5.0L engine, 2016-2017 Mustang equipped with a 5.2L engine, 2016-2017 Explorer vehicles equipped with a 2.3L EcoBoost engine or 2017 Escape/MKC vehicles equipped with a 2.0L EcoBoost engine may exhibit an engine oil leak. This may be due to the engine oil pressure (EOP) sensor threads leaking.
Action: Follow the Service Procedure steps to correct the condition.
Parts
Part Number     Description     Quantity
TA-24-B     Motorcraft Thread Sealant with PTFE     1
PM-4-A             Motorcraft Metal Brake Parts Cleaner     1
XO-5W20-QSP     Motorcraft SAE 5W-20 Premium Synthetic Blend Motor Oil – 5.0L     1
XO-5W30-QSP     Motorcraft SAE 5W-30 Premium Synthetic Blend Motor Oil – 2.0L, 2.3L, 2.7L     1
XO-5W50-QGT     Motorcraft SAE 5W-50 Full Synthetic Motor Oil – 5.2L     1
Warranty Status: Eligible Under Provisions Of New Vehicle Limited Warranty Coverage Warranty/ESP
coverage limits/policies/prior approvals are not altered by a TSB. Warranty/ESP coverage limits are
determined by the identified causal part and verified using the OASIS part coverage tool.
Labor Times
Description     Operation No.     Time
2015-2017 Edge 2.0L, Mustang 2.3L/5.0L/5.2L, 2016-2017 Explorer 2.3L: Inspect And Reseal The EOP
Includes Time To Clean Area And Check/Correct Engine Oil Level (Do Not Use With Any Other Labor
Operations)     172271A     0.4
2015-2017 F150 2.7L/5.0L, 2017 Escape 2.0L: Inspect And Reseal The EOP Includes Time To Clean Area And
Check/Correct Engine Oil Level (Do Not Use With Any Other Labor Operations)     172271B     0.7
2015-2017 Edge 2.7L: Inspect And Reseal The EOP Includes Time To Clean Area And Check/Correct Engine
Oil Level (Do Not Use With Any Other Labor Operations)     172271C     1.4
2017 MKC 2.0L: Inspect And Reseal The EOP Includes Time To Clean Area And Check/Correct Engine Oil
Level (Do Not Use With Any Other Labor Operations)     172271D     0.5
Repair/Claim Coding
Causal Part:     9278
Condition Code:     D8
Drive     Tool Name
1/4″     Ratchet
1/4″     Torque Wrench
1/4″     2″ Extension
1/4″     6″ Extension
1/4″     7 mm Socket
1/4″     8 mm Socket
1/4″     10 mm Socket
1/4″     Power Tool
3/8″     Ratchet
3/8″     Torque Wrench
3/8″     15 mm Socket
3/8″     21 mm Socket
3/8″     3/8″ to 1/2″ Adaptor
3/8″     Torx T-30 Socket
1/2″     Ratchet
1/2″     27 mm Socket
    Trim Tool
    Wire Brush
Service Procedure
1. Inspect the EOP sensor. Does the EOP sensor exhibit an oil leak at the sensor threads?
(1). Yes – proceed to Step 2.
(2). No – this article does not apply. Refer to Workshop Manual (WSM), Section 303-00.
2. Remove and reseal the EOP sensor, refer to WSM, Section 303-14. Clean the area as necessary.
3. Inspect and set the engine oil level as needed. Refer to WSM, Section 303-01.
  • Thanks 1
