tk2fast Posted December 27, 2018 Report Share Posted December 27, 2018 (edited) Just thought I would share "my" version for programming an extra key fob on my 2019 Edge Titanium. Also works on the 2018. I have read through the owners manual several times, finding mistakes or just omissions, which really surprised me. Anyway just trying to help others, so here is my slightly revised method after several tries form the OM. This works for 2018 – 2019 Ford Edge. Must have 2 programmed key fobs and 1 new unprogrammed key fob. Get in the car, close the doors and begin this process – must complete within 30 seconds, after pressing push button ignition switch 1st time. 1. Remove the key blade from all key fob transmitters. 2. Open the center console lid. With the buttons facing upward and the unlock button facing the front of your vehicle, place the first intelligent access key fob into the backup slot at the bottom front of the console. The “slot” is like a little bed for the key fob. Keep the key fob all the way toward the front of car in the “bed.” 3. Press the push button ignition switch. 4. Wait 3 seconds and then press the push button ignition switch again. 5. Remove the first intelligent access key fob. 6. Within 8 seconds, place a second programmed intelligent access key fob in the backup slot and press the push button ignition switch. 7. Wait 3 seconds and then press the push button ignition switch again. 8. Remove the second intelligent access key fob. 9. Then place the unprogrammed intelligent access key fob in the backup slot and press the push button ignition switch. You should hear the door locks activate; that's a good indication you are programmed. Programming should now be complete. Edited December 28, 2018 by tk2fast 2 1 Quote Link to comment Share on other sites More sharing options...
Guest Randy Posted October 8, 2019 Report Share Posted October 8, 2019 Bought a 2018 Ford Edge Titanium used. Only had 1 key. Is there a way to program a 2nd key fob without paying the money the dealer wants? Quote Link to comment Share on other sites More sharing options...
akirby Posted October 8, 2019 Report Share Posted October 8, 2019 No way around paying a dealer or a locksmith with a Ford diagnostic computer. Quote Link to comment Share on other sites More sharing options...
Guest SAM52752 Posted October 9, 2019 Report Share Posted October 9, 2019 What if you don’t have the second programmed fob. Can you use the first one twice Quote Link to comment Share on other sites More sharing options...
onyxbfly Posted October 9, 2019 Report Share Posted October 9, 2019 You must have two key fobs present in the vehicle at the same time. Quote Link to comment Share on other sites More sharing options...
akirby Posted October 9, 2019 Report Share Posted October 9, 2019 51 minutes ago, Guest SAM52752 said: What if you don’t have the second programmed fob. Can you use the first one twice Of course not. That defeats the purpose, which is to prevent someone unauthorized (a valet, a mechanic, a thief who has one key) from making a duplicate fob. Only the owner would have two different fobs so that makes it reasonably sure that you're the owner or at least authorized to make a 3rd fob. 1 Quote Link to comment Share on other sites More sharing options...
Davidg716 Posted January 8, 2021 Report Share Posted January 8, 2021 On 12/27/2018 at 12:18 PM, tk2fast said: 9. Then place the unprogrammed intelligent access key fob in the backup slot and press the push button ignition switch. You should hear the door locks activate; that's a good indication you are programmed. Programming should now be complete. Something good to add is that when you press the start button with the new fob in place, the car will do absolutely nothing for a few seconds. Unlike the two previous button presses where it turns the dash on. This actually stumped me for a bit. This might be a good article to pin to this forum since the owners manual instructions are wrong. 2 Quote Link to comment Share on other sites More sharing options...
GTSnake Posted April 23, 2024 Report Share Posted April 23, 2024 On 1/8/2021 at 8:43 AM, Davidg716 said: Something good to add is that when you press the start button with the new fob in place, the car will do absolutely nothing for a few seconds. Unlike the two previous button presses where it turns the dash on. This actually stumped me for a bit. This might be a good article to pin to this forum since the owners manual instructions are wrong. Yes, this threw me for a loop too. I thought it didn't work because there's a delay when the car is programming the new key. When I pressed the start button with the new key nothing happened and I thought something was wrong. Then after about 2 seconds the locks cycled and the hazards blinked. 1 Quote Link to comment Share on other sites More sharing options...
sc00by Posted June 25, 2024 Report Share Posted June 25, 2024 FWIW these steps also work on a 2020 Edge ST. The detail for the unprogrammed fob...waiting for the car is critical. 2 Quote Link to comment Share on other sites More sharing options...
