Remove Speaker Grill?
The grille is a part of that rear quarter panel...You can't simply just remove it.  If you want to get to the backside of it, you have to remove that whole panel, starting by removing the trunk sill first.  I just did this a few days ago trying to see what was acutally in there as it's an awfully large grille for the lack of sound it was putting out.
48 minutes ago, Jbob0124 said:
The grille is a part of that rear quarter panel...You can't simply just remove it.  If you want to get to the backside of it, you have to remove that whole panel, starting by removing the trunk sill first.  I just did this a few days ago trying to see what was actually in there as it's an awfully large grille for the lack of sound it was putting out.
@Jbob0124 Thanks for letting me know. Doubt I'll pull it, then. Pulling sills and side panels, probably best left to someone with more experience (and patience) than I. BTW, what did you find behind there?
3 minutes ago, Jbob0124 said:
Some mean looking clips and a lot of wasted space.  There is a 6.5" speaker there with a large enclosure.  Not much else.  Here is a link to an example (not mine) https://www.ebay.com/p/2015-2016-2017-Ford-Edge-Right-Rear-Woofer-Sony-Et4t-19a067-ac/11020401340.  Couldn't really find a better example.
That's the subwoofer in the "Premium" Sony sound package.? 'splains a lot ?
There is plenty of room for upgrading if someone wanted, the only limiting factor is space from the panel to the frame of the body.  Think it was roughly 6" from panel to frame.  Still plenty of room.  To be honest, I was kind of surprised to see such a small speaker there, considering the size of that grille.
