Transmission oil bolt check
renewill
  • 4 months later...
It should be behind the driver side wheel well. You might have to remove the cover. I changed my fluid recently and I measured the amount that came out and put it in. Also... If the car is level... It drains almost exactly 5 qts.  But keep in mind, it's a 2015 2.0L model. Not sure if you have the same.
Edited by 2011edgese
