2.0L 2 Line Catch Can Install?? Anyone??
Reptar
Looking for any info for installing a simple 2 line catch can on a 2015 Ford Edge 2.0L
It looks like I'm going to need some special Ford adapter clicks to plum into the PVC valve line? Or has someone just cut it and spliced in?
Here is the can
https://www.amazon.com/Vincos-Universal-Aluminum-Separator-Reservoir/dp/B076BKV7JF/ref=sr_1_8?s=automotive&ie=UTF8&qid=1544988296&sr=1-8&keywords=Catch+Can
Thanks in advance!
If I can figure this out all post pics on how to install later.
Thank you!
Ive read this one actually. It has 3 ports and not 2.
Hmm will update once I can find anything else. Thanks!
Here's what I've found.
Seems like you plug in right before the intake manifold? Then into your catch can, then from your catch can back into the vacuum line
on top of the engine.
Snagged the pics from the link, thanks!
First location
Then to catch can?
Then to vacuum intake
Edited by Reptar
Pics, update
Basically, you're going to cut/splice or add into the line going from the engine block to the intake manifold. You basically want to put it in between the engine block & intake manifold. The length of the lines going to the catch can doesn't really matter, so that you can mount it anywhere you have the space.
The purpose of the 3 line system is to also catch blow by during boost & vacuum.
Edited by lildisco
  • 5 months later...
