Reptar Posted December 16, 2018 Report Share Posted December 16, 2018 Looking for any info for installing a simple 2 line catch can on a 2015 Ford Edge 2.0L It looks like I'm going to need some special Ford adapter clicks to plum into the PVC valve line? Or has someone just cut it and spliced in? Here is the can https://www.amazon.com/Vincos-Universal-Aluminum-Separator-Reservoir/dp/B076BKV7JF/ref=sr_1_8?s=automotive&ie=UTF8&qid=1544988296&sr=1-8&keywords=Catch+Can Thanks in advance! If I can figure this out all post pics on how to install later. Quote Link to comment Share on other sites More sharing options...
lildisco Posted December 16, 2018 Report Share Posted December 16, 2018 This may be helpful: Clicky Clicky 1 Quote Link to comment Share on other sites More sharing options...
Reptar Posted December 19, 2018 Author Report Share Posted December 19, 2018 (edited) Thank you! Ive read this one actually. It has 3 ports and not 2. Hmm will update once I can find anything else. Thanks! Here's what I've found. Seems like you plug in right before the intake manifold? Then into your catch can, then from your catch can back into the vacuum line on top of the engine. Snagged the pics from the link, thanks! First location Then to catch can? Then to vacuum intake Edited December 19, 2018 by Reptar Pics, update Quote Link to comment Share on other sites More sharing options...
lildisco Posted December 19, 2018 Report Share Posted December 19, 2018 (edited) Basically, you're going to cut/splice or add into the line going from the engine block to the intake manifold. You basically want to put it in between the engine block & intake manifold. The length of the lines going to the catch can doesn't really matter, so that you can mount it anywhere you have the space. The purpose of the 3 line system is to also catch blow by during boost & vacuum. Edited December 19, 2018 by lildisco 1 Quote Link to comment Share on other sites More sharing options...
Tyler1011 Posted May 28, 2019 Report Share Posted May 28, 2019 Has anyone thought of using or tried installing the jlt catch can for the fusion 2.0? Quote Link to comment Share on other sites More sharing options...
