Auto Start/Stop on 2018 SEL 2.0 AWD
timfountain
1 hour ago, timfountain said:
Looking at the brochure for the MY 18, it looks like it was not installed on SEL AWD models. Only SE FWD....
https://www.ford.com/services/assets/Brochure?make=Ford&model=Edge&year=2018&postalCode=25508
Yep - order guide confirms it was only available on SE FWD.   Which begs the question as to why the option was in the menu?  They don't normally do that.
Exactly my thoughts. Why put a menu option for something that is non-functional, and why I started scratching  my head....
1 hour ago, jmr061 said:
You probably have an option in the cluster for auto engine off or engine auto off...
This is not the start/stop technology you are thinking of.
Aha!  I bet that’s it.   That’s the option to turn off the engine automatically after it idles for 30 minutes or so.
That is for turning off the engine in case of a long idle period, not sure it was 30 minutes or not. Even if you disable it, it will only be disabled for the current engine cycle (next time you restart the engine it will revert back to enabled). It is meant to turn off the engine in case you forgot to, which might happen with people not yet used to push button start.
