omar302 Posted December 1, 2018 Report Share Posted December 1, 2018 I previously used the MotorCraft TPMS tool to re-learn the wheel order, I didn't know that the Edge can auto learn the locations of each wheel/tire which I found by mistake after a wheel rotation. To test it, I had the front left tire inflated by +3 psi more than the other tires while it was still programmed as the rear left tire. After driving the Edge for a few minutes the system recognized the correct left front tire and reported the correct pressure (from 39 to 36 psi) and after a few seconds the left rear was also recognized and reading changed (from 36 to 39 psi). So a manual relearn using the Motorcraft TPMS tool is not required. Made the video to confirm this as it happened several times before. Doing the the relearing with the TPMS tool and mixing the order of learned tires will mixup the readings on the display, but after a few minutes driving the TPMS display will return to the correct order. 4 Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted December 2, 2018 Report Share Posted December 2, 2018 pretty cool stuff. finally! 1 Quote Link to comment Share on other sites More sharing options...
