Do you need wheel aligment when you replace rim?
t0lkman
Depending on the severity of the damage, i would get an alignment. Light curb rash usually doesn't require an alignment, but if she did enough damage to warrant a WHEEL replacement, then I would DEFINITELY get an alignment to cover all the bases. These newer vehicles are so tight within their specs, a big curb hit could knock it out of spec (which can also be said for pretty much every vehicle).
I'd plan on, at minimum & based solely on your description, 1 wheel replace & 4 wheel alignment. You may possibly need 2 new front tires, depending on the severity of the damage, which a tire shop should be able to tell you whether or not you need one.
