AntDeek Posted November 2, 2018 Report Share Posted November 2, 2018 I absolutely love how this 2013 SE has most of the wiring intact from higher trim levels. Previously I have added Ford factory (CANBUS) remote start using a hood pin switch kit and FORScan. To complement this, I have also added the extended range antenna kit from Ford, that plugs into the TPMS module, extending my fob and remote start range. I have since activated the DRL's as well, along with full LEDs except the halogens. My focus has switched to a newer "dummy" wire on my dash that would normally go to the Sunload Sensor for the autolamps. I thought to myself, "can I find 12v here? at least I could hard wire my radar detector if so!?" But no, its 5v. but its live! So now, my next challenge is to find a headlamp switch with the Autolamp feature and a Sunload Sensor. I realize I may have to do some deep diving with FORScan. Alternatively, I could just get a sunload sensor and jump the pins pretaining to autolamps in the current headlight switch connector. Anyone have any thoughts? 1 Quote Link to comment Share on other sites More sharing options...
PinoWhiteBoy Posted December 20, 2019 Report Share Posted December 20, 2019 Hey there! Were you able to figure this out? I too also have a 2013 Ford Edge SE. I already switched out the headlight switch for an automatic one. I played around in Forscan but no success. Thanks! Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted December 21, 2019 Report Share Posted December 21, 2019 There is a thread on the Ford Fusion Forum on how to do this, may be similar in nature. http://www.fordfusionforum.com/topic/7391-auto-headlights-install-on-a-se-easy/ Quote Link to comment Share on other sites More sharing options...
