evh Posted October 26, 2018 Report Share Posted October 26, 2018 I thought I would share this tip on how to potentially save $$$ on your next set of tires. Some background is needed. I just installed my fourth set of tires on my 09 Edge. I have tried all different brands (Goodyear, Bridgestone, Toyo, Coopers). None of them have come close to lasting as long as the warranty indicates. My most recent set lasted a little over 36,000 miles and they were 60,000 mile tires. 4/32” of tread remaining seems to be the cutoff point for the tire shops where they state that your tires are worn out. I am sure if you are where it doesn’t snow you could continue to run tires like that for a bit longer. Up here in the Snow Belt I want the most tread possible so I get new tires right away. I went back to the large chain tire store I bought my previous set at. They credited me $75 per tire! So I have a $300 credit toward my next purchase. I bought a set of 70,000 mile tires that also had a $70 rebate so I was out the door for $287. I really doubt this next set will last 70,000 miles. So if I still own this Edge, I will be back to the tire shop and get another set at a great discount. 1 Quote Link to comment Share on other sites More sharing options...
akirby Posted October 26, 2018 Report Share Posted October 26, 2018 Yep, treadwear warranty adjustments are common. But they do have to be down to the minimum spec as speciied by the tire mfr (I’ve seen some that say 3/32). And you are paying for that warranty so be sure to shop around even with the adjusted price. You might be able to find a different set even cheaper. But if you like those tires and want to stay with them, go for it. 1 Quote Link to comment Share on other sites More sharing options...
fishx65 Posted October 26, 2018 Report Share Posted October 26, 2018 (edited) I did this a few months ago at Discount Tire and ended up with a new set of Continental LX20's for $250.00 out the door. They gave me $200.00 total for my old set of Yoko YK580's plus there were a bunch of rebates at the time.. Had to hit a few different DT stores to get the best warranty amount for my old skins. Edited October 27, 2018 by fishx65 2 Quote Link to comment Share on other sites More sharing options...
evh Posted October 27, 2018 Author Report Share Posted October 27, 2018 I think the key is to remember to ask for it when you are getting your tires. I purchased the same tire measuring device like they use at the store so I knew when mine were at 4/32". I then went in and asked them to check my tires and see if they thought I needed new ones. Once they confirmed I did, I mentioned I purchased my last set here and I didn't get the full mileage. No issues after that. Note, I was also at Discount Tire. They did a great job. 1 Quote Link to comment Share on other sites More sharing options...
akirby Posted October 27, 2018 Report Share Posted October 27, 2018 As long as the tread is at the right depth and there is no other damage it’s usually a very easy process with no questions asked. 2 Quote Link to comment Share on other sites More sharing options...
