U128129 Posted October 18, 2018 Report Share Posted October 18, 2018 My car battery has been replaced three times in the past month and something is draining my battery. I thought it could be my APIM which is currently on recall however dealer said that was not it and to take battery back and have them replace with new one. It appears this is a common issue with these cars and unsure why after having my car at shop for almost a week I was told just replace battery and now after three days of my car sitting my car is dead again. Quote Link to comment Share on other sites More sharing options...
akirby Posted October 18, 2018 Report Share Posted October 18, 2018 Have you seen any errors such as "shift to park"? Bad shifter park sensor is one known problem. The BCM (body control module) is another. Quote Link to comment Share on other sites More sharing options...
U128129 Posted October 18, 2018 Author Report Share Posted October 18, 2018 Yes Shift to Park for a while. That error does not show up any longer. Quote Link to comment Share on other sites More sharing options...
U128129 Posted October 18, 2018 Author Report Share Posted October 18, 2018 Do you know how much this costs ? Quote Link to comment Share on other sites More sharing options...
U128129 Posted October 18, 2018 Author Report Share Posted October 18, 2018 Is this something thats currently an issue with many Fords and possibly under some sort of warranty? Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted October 18, 2018 Report Share Posted October 18, 2018 No extended warranty unless you bought one yourself. There is a TSB for the Shift to Park/Shifter Not in Park issue that confirms replacing a switch in the shifter assembly fixes the issue. 1 Quote Link to comment Share on other sites More sharing options...
U128129 Posted October 18, 2018 Author Report Share Posted October 18, 2018 Thank you so much. I am so grateful for your help and guidance. I looked into the entire cost of the Module and the cost is about $260.00 just for part no labor. Im going to inquire on TSB only and hope the cost is a lot less. Quote Link to comment Share on other sites More sharing options...
U128129 Posted October 18, 2018 Author Report Share Posted October 18, 2018 What does TSB stand for? Quote Link to comment Share on other sites More sharing options...
rwf78155 Posted October 18, 2018 Report Share Posted October 18, 2018 My 2013 ( which I traded in for a 2018 ) had the same issue. It turned out to be the shift to park system was not shutting systems down when the vehicle was turned off. My Ford extended warranty covered everything and even paid for a rental car while they waited for the repair parts Quote Link to comment Share on other sites More sharing options...
U128129 Posted October 18, 2018 Author Report Share Posted October 18, 2018 Thank you for your input. Im so happy that was covered under extended warranty. Quote Link to comment Share on other sites More sharing options...
akirby Posted October 19, 2018 Report Share Posted October 19, 2018 Technical Service Bulletin. It’s just a notice to dealerships on how to solve common problems. Quote Link to comment Share on other sites More sharing options...
U128129 Posted October 19, 2018 Author Report Share Posted October 19, 2018 Got it. Thank you again for all your help. Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted October 19, 2018 Report Share Posted October 19, 2018 You can read the entire thread for your own edification, but here is the TSB I was referring to, many thanks to omar302 for posting it! http://www.fordedgeforum.com/topic/11282-shift-to-park-warning-when-its-in-park/page-7?do=findComment&comment=183459 1 Quote Link to comment Share on other sites More sharing options...
