About tpms...
Ryanbai
Someone told me it’s not gonna work, because the frequency is different. Is that true?
Most US Ford vehicles use 315 MHz. Export models might use different frequencies. For Example, the US Edge uses 315 MHz while the GCC Edge from about 2013 uses 433 MHz.
You can check on http://etis.ford.com for your vehicle what is the frequency you Ford uses.
