ECU Programming Tool
Hi Guys,
I've been researching about ecu programming for a 2013 edge, there are many options that offer to be the best to improve power and economy. Do you have suggestions ?.
https://www.autoanything.com/performance-chips/jet-performance-module
https://www.chipyourcar.com/product/ford-performance-chips/
https://www.autoanything.com/performance-chips/hypertech-max-energy-programmer
thanks greetings
Edited by wmorastock
The first two are bogus garbage that will do nothing to improve performance and have the potential of damaging your vehicle. There is no such thing as a "chip" you can install in an Edge to improve performance - that's a thing from a bygone era when cars were much simpler.
The third is a true programmer that is designed to install custom tunes but doesn't support your 2013 Edge (the device would work but there are no tunes available that it could load). Livernois is a recognized expert in Edge programming and SCT tuners have been well received as well.
Whenever you consider these things, you need to ask yourself "If it was just simple programming that could improve power and economy, why didn't Ford do it from the factory?"
If you are in Chile, chances are you experience fairly severe conditions and possibly low quality of fuel. These are all things that are designed into the software from the factory, and doing any reprogramming could cause issues with driveability, emissions and durability.
