SEL Plus??
CN_Hogger
Just registered with FordOwner.com, put in my correct VIN and all and it's saying I have an SEL Plus when I have a limited? What's up with that??
That's normal. I ordered a Limited and it said the same thing when I checked my VIN. It was a Limited when it showed up.
They must not have internally changed the terminology.
Hi Cn_Hogger. :D Same thing, so don't worry about it. When the Edge was first introduced, the 3 trim levels were SE, SEL and SEL Plus. The Limited trim level designation simply replaced the SEL Plus (I believe for the 2008 models).
They probably will eventually update the database and it will be registered as a Limited.
Good luck. :beerchug:
EDIT - SHIZZY typed faster than me! :stats:
Edited by bbf2530
