oil drain plug location
zinc76
Locate the OIL Filter at the front of the vehicle (obviously under the car)..
(The OIL Filter is right next to the front bank exhaust...)
Next, from the OIL Filter, looking towards the rear of the vehicle, you will immediately notice an
Aluminum pan...This is the Engine OIL pan....
At the back of this OIL pan (once again, looking towards the rear of the car) right before the driveshaft, you will notice a "plug" ...This is the OIL draning "plug"...Remove and let it drain...
A good 1/2 hr or longer (if you're not in a rush) to ensure that you get as much of the old oil out.
Remember, the EDGE takes 5 1/2 quarts of Oil once you fill up..
