Stumpalump Posted May 13, 2008 Report Share Posted May 13, 2008 Has anybody dove into the transmission controller electronics to see if we can wire in a toggle switch to manually select the gears we want? It would be nice on the long downhills here in Colorado. Quote Link to comment Share on other sites More sharing options...
IZZYAZ Posted May 13, 2008 Report Share Posted May 13, 2008 That has to be my biggest complaint about the Edge, is not being able to control the gears. Living here in Iowa, I don't have the problems with mountains like you do in Colorado, but when I do pull trailers, it would be nice to use the engine a little bit better. Quote Link to comment Share on other sites More sharing options...
akirby Posted May 13, 2008 Report Share Posted May 13, 2008 Has anybody dove into the transmission controller electronics to see if we can wire in a toggle switch to manually select the gears we want? It would be nice on the long downhills here in Colorado. That's possible only if the PCM software already has the logic. I've seen it done on a Lincoln LS where the sport models had the manumatic shifter and the base models did not - you just swapped in a new shifter and reflashed the PCM to think it was a sport model. Since no versions of the Fusion or Edge have manumatic shifting there is probably no chance of making it work. Quote Link to comment Share on other sites More sharing options...
dean7698 Posted May 26, 2008 Report Share Posted May 26, 2008 The Lincoln MKS will have the same transmission as the Edge, but with a slightly lower K-factor torque converter and it will have the manumatic shifting capabilities. Job 1 for it was May 5 so keep an eye out for it in the near future at dealers near you. More importantly with regards to this topic is you may be able to derive something from the MKS. Quote Link to comment Share on other sites More sharing options...
dean7698 Posted May 26, 2008 Report Share Posted May 26, 2008 Forgot to mention, I'm not sure yet if the Edge will get the manumatic shifting at the refresh or not. I think it will though. Quote Link to comment Share on other sites More sharing options...
CreamEDGE. Posted May 26, 2008 Report Share Posted May 26, 2008 The MKS's transmission has to be beefed up to handle the extra power from the new twin force engine, the 6F in the EDGE can only handle about 325FT-LB's of torque. Quote Link to comment Share on other sites More sharing options...
Stumpalump Posted August 20, 2008 Author Report Share Posted August 20, 2008 I've been driving in the mountains and must say that I like the transmission now. If you take it out of overdrive on a long mountain grade it will automatically keep down shifting to maintain your speed. If I crest Vail pass at 60 and kick it out of overdrive then it will downshift to 5th. If I just keep coasting faster it will shift to 4th when it hits about 64. Let her roll and it will shift tio 3rd all by itself to hold you speed constant. It's just like cruise controll holding your speed but keeping you slowed down instead of at speed. Very cool. it works on small hills also so give it a try and you see how it works. Quote Link to comment Share on other sites More sharing options...
USAF_Ron Posted September 9, 2008 Report Share Posted September 9, 2008 I've been driving in the mountains and must say that I like the transmission now. If you take it out of overdrive on a long mountain grade it will automatically keep down shifting to maintain your speed. If I crest Vail pass at 60 and kick it out of overdrive then it will downshift to 5th. If I just keep coasting faster it will shift to 4th when it hits about 64. Let her roll and it will shift tio 3rd all by itself to hold you speed constant. It's just like cruise controll holding your speed but keeping you slowed down instead of at speed. Very cool. it works on small hills also so give it a try and you see how it works. Have you tried your engine braking (OD off) in the snow? Thx. Quote Link to comment Share on other sites More sharing options...
rmmpe Posted September 9, 2008 Report Share Posted September 9, 2008 Although I like the "Hill descent" feature of the trans, I'd really like to have the capability of manual gear selection. The gears are there but without a way to actively control them, it's a poor compromise. If anyone finds out more about flashing the PCM to gain that ability, please let me know. I have a small Joystick just waiting for a place to call home. Quote Link to comment Share on other sites More sharing options...
akirby Posted September 9, 2008 Report Share Posted September 9, 2008 Although I like the "Hill descent" feature of the trans, I'd really like to have the capability of manual gear selection. The gears are there but without a way to actively control them, it's a poor compromise. If anyone finds out more about flashing the PCM to gain that ability, please let me know. I have a small Joystick just waiting for a place to call home. Since none of the Edge versions come with that feature, none of the PCM codesets will have it either. You need the software in the PCM to control it. That works on cars that offer the feature - you just change the shifter and reflash the PCM. Quote Link to comment Share on other sites More sharing options...
MDJL Posted September 14, 2008 Report Share Posted September 14, 2008 Too bad the cx-9 has it, based on same platform, but comps are probably totally different. Quote Link to comment Share on other sites More sharing options...
akirby Posted September 15, 2008 Report Share Posted September 15, 2008 Too bad the cx-9 has it, based on same platform, but comps are probably totally different. Different computer and different transmission. Quote Link to comment Share on other sites More sharing options...
