toast1850 Posted September 28, 2018 Report Share Posted September 28, 2018 Can anyone tell me how to remove driver side door check for a 2014 Edge? I bought a replacement because mine makes a popping noise when I open the door. Any help is appreciated. Quote Link to comment Share on other sites More sharing options...
akirby Posted September 29, 2018 Report Share Posted September 29, 2018 Door check?? Quote Link to comment Share on other sites More sharing options...
toast1850 Posted September 29, 2018 Author Report Share Posted September 29, 2018 Yeah see the pic I attached. It looks like I will have to remove the entire door panel. Was hoping it would be easy. Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted September 30, 2018 Report Share Posted September 30, 2018 diagram here: https://parts.levittownfordparts.com/auto-parts/2014/ford/edge/sel-trim/3-5l-v6-gas-engine/body-cat/front-door-scat 22 AT4Z-7827204-A Door Check Door Check, RIGHT, LEFT $39.17 $27.03 Ā Door Check ArmĀ tem Part Number Description 1 23552 Door check arm 2 W713778 Door check arm-to-body bolt 3 W712741 Door check arm-to-door nuts Removal and Installation Remove the door trim panel. For additional information, refer to Section 501-05 .Remove the door check arm-to-body bolt. To install, tighten to 20 Nm (177 lb-in). Remove the door check arm-to-door nuts. To install, tighten to 9 Nm (80 lb-in). To install, reverse the removal procedure.Ā The door trim panel is fairly straightforward, the inner panel can be tricky if the bolts don't cooperate. One video where the removal is illustrated as part of a window replacement procedure: Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted October 1, 2018 Report Share Posted October 1, 2018 Try spraying it with silicone spray first. Probably dirt causing it to bind creating the poping as it releases. (I use WD40 Dry Lube on mine). 1 Quote Link to comment Share on other sites More sharing options...
toast1850 Posted October 1, 2018 Author Report Share Posted October 1, 2018 Yeah I tried that a while back and it didn't help. I specifically bought that type. It pops pretty bad and can be embarrassing if someone rides with me and hears it. So it's time to replace it. 1 Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted October 1, 2018 Report Share Posted October 1, 2018 How many miles on your Edge if I may ask? Quote Link to comment Share on other sites More sharing options...
toast1850 Posted October 1, 2018 Author Report Share Posted October 1, 2018 Around 46,000. It's a 2014. I do have an extended warranty on it but it's not through Ford. It's one of those third party warranties they sold me when I financed it. I could probably go through the warranty, but I think I have to cover a deductible first. I would have to check my paperwork to see how much. The passenger side started recently also but it's not near as bad as the driver side. 1 Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted October 2, 2018 Report Share Posted October 2, 2018 Doubt a third-party warranty will cover it as it hasent failed (just creates a poping sound). 1 Quote Link to comment Share on other sites More sharing options...
toast1850 Posted October 9, 2018 Author Report Share Posted October 9, 2018 Just to confirm, I did have to remove the entire door panel just to get to this part. But no more popping! 1 Quote Link to comment Share on other sites More sharing options...
