Door check replacement
toast1850
diagram here:
https://parts.levittownfordparts.com/auto-parts/2014/ford/edge/sel-trim/3-5l-v6-gas-engine/body-cat/front-door-scat
22 AT4Z-7827204-A Door Check
Door Check, RIGHT, LEFT
$39.17 $27.03
Ā
Door Check Arm
Ā
tem Part Number Description 1 23552 Door check arm 2 W713778 Door check arm-to-body bolt 3 W712741 Door check arm-to-door nuts
Removal and Installation
  1. Remove the door trim panel. For additional information, refer to Section 501-05 .
  1. Remove the door check arm-to-body bolt.
    • To install, tighten to 20 Nm (177 lb-in).
  1. Remove the door check arm-to-door nuts.
    • To install, tighten to 9 Nm (80 lb-in).
  1. To install, reverse the removal procedure.
Ā
The door trim panel is fairly straightforward, the inner panel can be tricky if the bolts don't cooperate.
One video where the removal is illustrated as part of a window replacement procedure:
Around 46,000. It's a 2014. I do have an extended warranty on it but it's not through Ford. It's one of those third party warranties they sold me when I financed it. I could probably go through the warranty, but I think I have to cover a deductible first. I would have to check my paperwork to see how much. The passenger side started recently also but it's not near as bad as the driver side.
