car has a mind of its own
APL111
Hello again
Seems my wifes car has a mind of its own. First off their are no idiot lights on dashboard abs lights off. The problem is the abs will kick in when their is no need for it. The abs is pulsing the brakes yet it does not show the abs engaged on dashboard, maybe that is not lit when abs is engaged. The drivers front cv axles going to be replaced its boot is torn. Since the abs light/cel lights off I cant pull codes. I am thinking grease from axle got on rotor and contaminated brake pads. Or a wheel speed sensor is dirty. I tried cleaning off the entire area with brake cleaner and no luck.. Thing is sometimes it brakes fine other times it seems the ABS has a mind of its own. I am confused as I cant pull any codes or they are not visible. The Edge has 120,xxx miles on it. Thank you.
Tony
