Blivit Posted September 19, 2018 Report Share Posted September 19, 2018 Long time reader....seldom post.... I had a 2007, FWD with 170k miles at this point. It was the wifes daily driver until last week when we donated it to a friend that needed a vehicle. It was always great to us and I took good care of it and it never had any major problems. 2.5 years ago, the radiator cooling fan stopped working. I bought an aftermarket complete assembly, installed it and that fixed the issue and everything was fine for 2.5 years, even here in Florida. Last week, after giving the car to our friend, the fan kicked on the next day and wouldn't shut off, even after removing the key from the ignition. The only way to shut it off was to pull the fuse or disconnect the battery. AC works fine still regardless and the temp gauge reads normal. She lives close and I told her I would continue to help maintain it within reason. I checked the voltage at the connector going into the control module and it's constant 12-14v across the black and red (engine off vs engine on) and switched 0-12v across the black and middle wire (green?) when the ac is off vs on. This seems to be correct which tells me the module has failed. Seem plausible? I know these assemblies have issues and aftermarket seems to be frowned upon..but the price was right for my purpose. The one I purchased lists that it has a "lifetime warranty" so I know if I work on it, I can probably get it a new one, I just don't want to go through with that if it may be something else. Thoughts? Quote Link to comment Share on other sites More sharing options...
akirby Posted September 19, 2018 Report Share Posted September 19, 2018 They can run after engine shutdown if the engine is too hot. See how long they run - if it's only a couple of minutes it's normal - check the coolant level. 1 Quote Link to comment Share on other sites More sharing options...
Blivit Posted September 19, 2018 Author Report Share Posted September 19, 2018 They can run after engine shutdown if the engine is too hot. See how long they run - if it's only a couple of minutes it's normal - check the coolant level. Thank you. Coolant level is fine and it has stayed on long enough to completely drain the battery. Quote Link to comment Share on other sites More sharing options...
akirby Posted September 19, 2018 Report Share Posted September 19, 2018 In that case I'd say you need a new fan assembly and controller. On the Edge they're sold together as one unit. 1 Quote Link to comment Share on other sites More sharing options...
Blivit Posted September 27, 2018 Author Report Share Posted September 27, 2018 Back with an update....not fixed yet. Ordered and installed a new module, same as last time...still doing the same thing; fan does not shut off. I did what I could to help but threw in the towel and had her take it to a shop. Even when we told them a new module didn't fix it, they too thought that was the issue. So they ordered one as well, installed it, didn't fix it big surprise. At this point they think it's the pcm but are running more tests. Quote Link to comment Share on other sites More sharing options...
omar302 Posted September 27, 2018 Report Share Posted September 27, 2018 Did you install a MotorCraft fan assembly? Quote Link to comment Share on other sites More sharing options...
Blivit Posted September 27, 2018 Author Report Share Posted September 27, 2018 Did you install a MotorCraft fan assembly? No, aftermarket. TYC brand, same that I put in 2.5 years ago that had no issues. I am not sure what the shop put in. I know aftermarket is frowned upon. Quote Link to comment Share on other sites More sharing options...
omar302 Posted September 27, 2018 Report Share Posted September 27, 2018 Did you change the whole fans & module or only the module? If only the module, maybe the issue is from the fans? Quote Link to comment Share on other sites More sharing options...
Blivit Posted September 27, 2018 Author Report Share Posted September 27, 2018 Did you change the whole fans & module or only the module? If only the module, maybe the issue is from the fans? Both times it was the entire assembly as I haven't found just the module. Quote Link to comment Share on other sites More sharing options...
akirby Posted September 27, 2018 Report Share Posted September 27, 2018 Aftermarket fan assemblies are DOA more often than they work. That’s why we recommend OEM/Motorcraft. 1 Quote Link to comment Share on other sites More sharing options...
vega Posted September 28, 2018 Report Share Posted September 28, 2018 Gee, please let us know the final solution to this weird problem. Quote Link to comment Share on other sites More sharing options...
Blivit Posted October 1, 2018 Author Report Share Posted October 1, 2018 It was the module. Motorcraft unit fixed it. It wasn't that I didn't trust or believe what was said here, I just couldn't justify the price difference. I suppose I got lucky with my initial aftermarket unit lasting 2.5 years. The replacement I bought (same brand) was DOA. The shop it was taken to also tried an aftermarket unit (unsure of brand) which was also DOA. Thankfully the shop worked with us and didn't charge us for that unit or any of the labor. 2 Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted October 1, 2018 Report Share Posted October 1, 2018 Nobody's disassembled the aftermarket modules that I know of. I guess you would have to get a failed one to not pay out the wazoo. Quote Link to comment Share on other sites More sharing options...
Blivit Posted October 1, 2018 Author Report Share Posted October 1, 2018 Nobody's disassembled the aftermarket modules that I know of. I guess you would have to get a failed one to not pay out the wazoo. It would be interesting to dissect these things. Unfortunately that isn't in the cards for me. The car is fixed and back with the new owner; my edge time appears to be done. I would also like to point out, the second aftermarket unit I bought (both from Amazon...same part number on both) had 2010+ Edge on the box (didn't notice that until later.) The module itself also had a different part number from the one I removed from the vehicle. Either way, they both had failed but it appears things had changed. 1 Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted October 1, 2018 Report Share Posted October 1, 2018 Ford often has running production changes. The only way really to confirm is to check on dealer sites or directly on parts.ford.com to see when the changes became effective. Sometimes only the most recent change is available for perusal for the public, so it is what it is. Quote Link to comment Share on other sites More sharing options...
