2013 Ford Edge 10 Amp parasitic drain
Yodawill2000
Hello folks!
New member here.
I have a nasty battery drain when the ignition is off.
I eliminated the Alternator by disconnecting the main cable.
I used a thermal imaging device to see what was getting warm and I found a connector right beside the inside fuse box the was heating up.
Its a light gray Molex type connector on the right side of the fuse box about half way up.
When I disconnect the cable the parasitic drain stops. the ignition is non responsive also when its unplugged..
Can anybody tell me what devices use that connection?
Cant find a wiring diagram anywhere online.
Thanks in advance for any help.
Disconnecting the battery when I shut it off is getting old!!!
10 amps is a huge drain! Normal drain (to maintain clock, keyless entry, etc.) should be 50 milliamps or less on most recent models - even less on older models with less electronics. Some GM models have been known to approach 90 milliamps but that is still more than 100 times less than your 10 amps. There are lots of circuits in the vehicle that don't draw 10 amps even when they're turned on.
Just guessing based on your description, but you may be unplugging the power lead coming into the fuse box.
My initial guess is the problem lies in the fuse panel itself. This part actually contains several transistorized circuits that can fail.
That being said there is a way to troubleshoot the problem.
Connect a VOM (set to amperes) between the positive battery lead and the battery (in series). (This is what you did to determine the leak current.
Next disconnect each fuse, one-by-one, and check to see if the draw stops. (There is always some draw coming from the battery, but it's in millimeters.)
If after testing all circuits, you do not find a specific circuit, it's the fuse panel (smart junction box) itself. Otherwise you will have isolated the circuit that's causing the draw.
Post back your results, we are all curious.
Edited by enigma-2
Update on this. Finally!
Work has been a beast the last week.
I was pulling a fuse at a time to see if I can find the culprit.
I had my wife watching the Amp gauge by the battery.
Turns out there is a click sound at the inside fuse box area like a relay when she closes the circuit with the meter. When I pulled fuse #18 the clicking stopped and the drain went down quite a bit.
Here is what the fuse powers per the diagram.
Third row power seats, Start button run indicator, Keypad illumination, Brake shift interlock, Powertrain control module wake-up, Anti-theft system.
I did pull out the 2 small relays in the fuse box itself, but that didn't stop the clicking sound.
