Front end shaking during right sweeper curve
EdgeMG13
Hey All,
I've tried searching throughout the forums (and web), but can't seem to find a similar thread/post so I apologize in advance if this is a duplicate topic.
I have a 2013 Ford Edge SEL, AWD 3.5L with 115K miles, and recently I've been noticing a shake/wobble during right hand sweepers/ curves (feels like front driver side wheel?). It will only happen on slight curves to the right at 40-60mph, and will worsen if the brakes are used. As soon as I straighten the wheel out, or turn harder to the right the shaking will disappear.
I've replaced the front brake pads and rotors thinking it was warped rotor/ pad, but of course the issue remains. I've had new tires put on and rotated within the last 10K miles, and I have noticed slightly more wear on the inside tread of the front driver side tire.
I'm in the North East, and there's always more pot holes than flat surfaces so I'm sure something is due for replacement. However, most shops in the area are unfortunately not very trustworthy, and I'd like to have some idea of what the issue might be instead of wasting money and replacing the entire front end.
Any help, suggestions and advice is greatly appreciated!
MG
