akirby Posted October 8, 2018 Report Share Posted October 8, 2018 On 10/8/2018 at 9:18 PM, shumax said: You are comical. Wrong oil weight would not cause that sort of an issue in 9,000 miles. I've been around engines long enough to know that. There is no way. I mean, seriously. If you were in my shoes, you'd feel a similar way. Because you aren't there, don't defend it. Your pontificating on behalf of Ford is ridiculous. Ford has an issue with the 2.7 Eco motor; it's a well known issue across the F150 and Fusion forums. This isn't a "one off" issue. There is no way poor treatment on the part of the prior owner contributed to the issue. Ford had an issue, as outlined in the TSB's, that led to this issue. It's as simple as that. You're making more out of it than is there. I will not argue with you on a forum. It's ridiculous. Enough... Shumax I’m just trying to get you to see it from Ford’s standpoint, which you don’t seem interested in, so let’s just move on. I never said they shouldn’t fix it under warranty, and that’s exactly what they’re doing. 1 Quote Link to comment Share on other sites More sharing options...
shumax Posted October 8, 2018 Author Report Share Posted October 8, 2018 I agree. As I started this post, I remain optimistic even though the track record is against me. Time will tell and, worrying about it, is a waste of time. I will drive it, see how it goes, and go from there. Thats all you can do! 1 Quote Link to comment Share on other sites More sharing options...
1004ron Posted October 9, 2018 Report Share Posted October 9, 2018 On 10/8/2018 at 9:18 PM, shumax said: You are comical. Wrong oil weight would not cause that sort of an issue in 9,000 miles. I've been around engines long enough to know that. There is no way. I mean, seriously. If you were in my shoes, you'd feel a similar way. Because you aren't there, don't defend it. Your pontificating on behalf of Ford is ridiculous. Ford has an issue with the 2.7 Eco motor; it's a well known issue across the F150 and Fusion forums. This isn't a "one off" issue. There is no way poor treatment on the part of the prior owner contributed to the issue. Ford had an issue, as outlined in the TSB's, that led to this issue. It's as simple as that. You're making more out of it than is there. I will not argue with you on a forum. It's ridiculous. Enough... Shumax Wonder why these failures don't appear to plague the Edge. 1 Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted October 9, 2018 Report Share Posted October 9, 2018 Hey, Ron, we got enough to deal with already, don't jinx it! LOL. 1 Quote Link to comment Share on other sites More sharing options...
shumax Posted October 21, 2018 Author Report Share Posted October 21, 2018 Update: We've driven the car just at 300 miles. I've been checking the oil every 3-4 days and it's been fine, until today. I checked the oil - cold engine. The oil level is at the first hole in the dipstick. So, it's gone from the top hole to the bottom hole in about 80 miles. You can imagine the feeling I had when I saw that. I'm not touching it. It's going back to the dealer tomorrow to have them check the oil after it's sat for an hour. Part of me wonders it it's slightly normal on a "new" engine, to burn some. But, given the history with this engine, I'm not as willing to accept that. Any thoughts? Shumax Quote Link to comment Share on other sites More sharing options...
1004ron Posted October 21, 2018 Report Share Posted October 21, 2018 (edited) On 10/21/2018 at 8:33 PM, shumax said: Update: We've driven the car just at 300 miles. I've been checking the oil every 3-4 days and it's been fine, until today. I checked the oil - cold engine. The oil level is at the first hole in the dipstick. So, it's gone from the top hole to the bottom hole in about 80 miles. You can imagine the feeling I had when I saw that. I'm not touching it. It's going back to the dealer tomorrow to have them check the oil after it's sat for an hour. Part of me wonders it it's slightly normal on a "new" engine, to burn some. But, given the history with this engine, I'm not as willing to accept that. Any thoughts? Shumax What "history" do you have with that new engine? Mine has 31K miles on it now and has never needed topping up between oil changes - it remained at the top hole on the dipstick throughout. Edited October 21, 2018 by 1004ron Quote Link to comment Share on other sites More sharing options...
shumax Posted October 21, 2018 Author Report Share Posted October 21, 2018 I'm referring to the first one that had to have the cylinder heads replaced due to burning oil and then was eventually replaced - as noted in this thread. Is it normal to use that much oil in 80 miles after the engine was replaced 300 miles ago? Shumax Quote Link to comment Share on other sites More sharing options...
1004ron Posted October 21, 2018 Report Share Posted October 21, 2018 (edited) "But, given the history with this engine" On 10/21/2018 at 9:12 PM, shumax said: I'm referring to the first one that had to have the cylinder heads replaced due to burning oil and then was eventually replaced - as noted in this thread. Is it normal to use that much oil in 80 miles after the engine was replaced 300 miles ago? Shumax You have a history of 300 miles with this engine, a new factory replacement engine. "as noted in this thread" - the bulk of this thread refers to the original defective engine. No its not normal for a new engine to use or lose a load of oil in just 80 miles. Edited October 21, 2018 by 1004ron Quote Link to comment Share on other sites More sharing options...
shumax Posted October 21, 2018 Author Report Share Posted October 21, 2018 One of isn't reading the other correctly, which I'm not concerned about. You confirmed my suspicion which is the use of that much oil, in 80 miles (or even 300), is excessive. Thank you, Shumax Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted October 22, 2018 Report Share Posted October 22, 2018 (edited) Any burning oil in the exhaust? (Blue exhause). And oil puddles under the engine when it sits? (Wondering if its burning it or leaking it)? Although I imagine this is a silly question, but have you checked the oil filter to see if it's on tight? Normal oil consumption for a new engine is around 1/2 quart between oil changes. Edited October 22, 2018 by enigma-2 Quote Link to comment Share on other sites More sharing options...
shumax Posted October 22, 2018 Author Report Share Posted October 22, 2018 I should have mentioned that - no leaks. Also, my wife drives the car, so she doesnt pay as much attention to smoke coming out the rear. However, since this all started( issues with the first engine), I asked her to and she contends she hasnt seen anything... 1 Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted October 22, 2018 Report Share Posted October 22, 2018 I would guess then, that the only other way an engine can lose oil is by blowing out when driving (that is, when pressure is high). There should be an oil residue where the leak is occuring. 1 Quote Link to comment Share on other sites More sharing options...
