Sync 3 Nav upgrade - quick question
I recently installed a NAV-enabled APIM in my 2018 2.0T SEL. The APIM was programmed with the correct VIN and the center 8" screen works fine.I can't recall completely, but my memory of rental Edges' is that the Nav menu also shows up in the right hand display in the main instrument cluster. Can anyone confirm whether that is true or not? Further if it is correct, does anyone know how to enable it, I presume a visit to the dealer....
TIA
- Tim
Edited by timfountain
@omar301, do you know if by any chance this can done for Android Auto maps? that would be fantastic.
As far as i know, on the stock Navigation shows in the cluster. But I do not have Sync 3 and have no experience with it. Even though my Edge is a 2016, being an Export model, it has Sync 2 (MyFord Touch). Sync 3 came to our region starting with 2017 models.
Hmm. I got ForScan, licensed and a USB ELM Config from ohp with the switch. I can see the IPC module but my default config for the 720-05-01 is D028 0000 00B0 which does not match the details given in the linked modsheet which should be D8B8 xxxx xxxx (no Nav). I'm sure it is something simple but darned if I can see it.
--> Does anyone have a 2017/18 with nav and who would be willing to read the 720-05-01 block in their IPC and report back? I'd be eternally grateful. Thanks@
I've got a 2016 Edge with Sync 3 and Nav. I can take a look at 720-05-01 later today and let you know what I see tonight.
However, from looking at the mod sheet, it looks like the 2 in D028 means no climate control without nav. D038 would mean no climate control with nav. The default value for nav is D8B8 and the default value for no nav is D8A8. Those codes are hexadecimal values and if you break them down to binary, it appears that there is one bit that is the toggle for the nav menu. I'm looking specifically at the third digit in D028/D038/D8A8/D8B8 and the fourth binary digit of that third hexadecimal digit. (I'll try to keep the computer gibberish to a minimum).
In binary 2 is 0010, 3 is 0011, A is 1010 and B is 1011. Think of those binary digits as toggle switches. That fourth binary digit is the one that appears to be the nav menu toggle. It's 1 (or on) for each code for nav and 0 (or off) for each code for no nav. The first binary digit appears to be the toggle for climate control. I don't have climate control on my right screen, so I would guess that my code is D038 right now or maybe D838. I'm not sure what the second hexadecimal digit does.
If you're seeing D028 right now, I'd change that to D038 to enable the nav menu on the right screen. Changing it to another value means that you would be changing other bits (or toggle switches) and we don't necessarily know what they do.
Edit: I just downloaded my as-built data from the Ford/Motorcraft site and it shows 720-05-01 on my vehicle as D838.
Edited by Quila
Thank you so much. The suggested value D038 worked just fine. I really appreciate your help.
