VCT Solenoid leaking
Clyde Epperson
Watch macbwt's video on how to take the valve cover off. Although on a 2011, basically the same process to take off on a 2008. 2011 has 2 VCT solenoids per bank since both intake and exhaust are variably controlled. 2008 only has 1 as only the intake is variably controlled.
A new valve cover gasket is advised
7T4Z-6M280-C Control Valve Solenoid
EDGE, MKX
$83.37 $57.52
7T4Z-6584-B Valve Cover Gasket
Valve Cover Gasket, RIGHT
$14.53 $10.03
https://parts.levittownfordparts.com/auto-parts/2008/ford/edge/sel-trim/3-5l-v6-gas-engine/engine-cat/engine-parts-scat
Removal and Installation
  1. Remove the LH or RH valve cover. For additional information, refer to Section 303-01 .
  1. Remove the bolt and the Variable Camshaft Timing (VCT) oil control solenoid.
    • To install, tighten to 10 Nm (89 lb-in).
  1. To install, reverse the removal procedure
Edited by WWWPerfA_ZN0W
  • 6 years later...
I've got abnormal oil consumption - I added 1qt after 1300 miles. My aftermarket VVT solenoids get wet with oil on the top around connectors(got 'em from O'Reilly). Compression 10,5-11(the tool was loosing a rubber cone on its end). I've found that the thread on the spark plug was covered with oil. I replaced plugs 5k miles ago using aluminum anti seize on a thread - now it's oiled. No oil around the plug inside plugs chambers...
Edited by NzP
  • 2 months later...
Any suggestions?
I think I'll try to clean the seals and solenoid carefully and apply an RTV around. So if the oil still going to appear on the top of solenoid it means the solenoid itself is defective(leaking trough itself)? Bank 1 had that leak almost right away since I replaced it, bank 2 just started to get a tiny bit oiled(
P.S.: solenoids seals are new and(maybe) leak, spark plug seals still original and they don't leak. I wish it not a solenoid, cz I watched a video it's possible to replace solenoid seals without valve covers off..
So as I mentioned in the other thread - I still have a little engine vibration. I've just found an information if the VCT solenoid leaks then the engine could run rough damaging timing components. But since I replaced VCT solenoids 7k miles ago - I've never seen any MIL or any stored codes at all.
Edited by NzP
