2015 Edge P1450 code repaired, now P1451 code showing
Ever since the introduction of the capless fuel filler, there have been numerous reported failures of the EVAP Purge Valve, much less so of the canister vent valve. The purge valve is in the engine bay, and the vent valve is underneath the passenger compartment along with the EVAP canister.
I would pull vacuum on the purge valve to see if it is faulty. If it is in working order, a smoke test is the best way to figure this out.
