Edge `07 SEL - Traction Control & Brake System Warning Lights Up
Hi Guys,
I just came back from holidays with mit Edge, and on the Autobahn these two warning lights came up sporadically. Sometimes it came up on bumps, then it goes out on the next bump, then it came up when I went down the hill or when I accelerated.... really very.
Sometimes it was on for 10 minutes, then nothing was lighting up for 2 hours...
What could be the problem? Brake Fluid is full.
I have noticed one tire had less pressure, but nothing changed after I filled it up again.
  • 4 weeks later...
Unfortunately, it is usually the sensor ring, a toothed ring attached to the halfshaft. Look for it behind the wheel and see if it is cracked, corroded, or damaged.
If you're lucky, it will be the sensor, which is fairly cheap and easy to replace.
Do you have a Diagram or picture of the sensor ring.
Also can you give me a link to the part on rockauto.com
BTW.... the error codes my buddy has found are:
C1140-20
B1320
B1485
B1696
C1125-20
Edited by CivicSi907
I have had a similar problem as well. My bet it is the Tone Ring. I have had that on two (or three?) wheels on my Edge and the system acts a bit weird. I am dealing with it on my Daughter's 2008 Ford Escape. In researching it on the Escape I found this write-up and thought it is very applicable to the Edge as well. Nicely written with photos.
https://therangerstation.com/forums/showthread.php?t=85395
My mechanic and me checked all 4 tone rings. And they look fine. Anyway...why does the lights just go on in the morning tow and after a few driving meters they go off and stay off.
