Jsb2601 Posted August 27, 2018 Report Share Posted August 27, 2018 Hi, I am trying to replace the signal light on the left side mirror of my 2016 edge titanium. I have removed the cover and it looks to remove easily, but there is one connection I cant figure out how to undo to finish removing the old signal and installing the new. I appreciate the help! Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted August 28, 2018 Report Share Posted August 28, 2018 (edited) Exterior mirror glass4. Position the exterior mirror glass fully in and up.5. Remove the exterior mirror glass. 1. Using a flat blade screwdriver, release the exterior glass. 2. Disconnect the exterior mirror glass electrical connections. Exterior mirror bezel 9. Remove the exterior mirror cover. 10. Remove the screws and the exterior mirror bezel. Exterior mirror mounted turn signal 11. Remove the exterior mirror bezel. 12. Remove the exterior mirror mounted turn signal. 1. Position the turn signal assembly up. 2. Disconnect the turn signal electrical connector. Edited August 28, 2018 by WWWPerfA_ZN0W Quote Link to comment Share on other sites More sharing options...
Jsb2601 Posted September 3, 2018 Author Report Share Posted September 3, 2018 (edited) Hi. I still should remove the glass, even though I can get to te signal by removing the outer cover? I would paste a picture if i could. Edited September 3, 2018 by Jsb2601 Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted September 4, 2018 Report Share Posted September 4, 2018 If you can get to the signal without removing the glass, then all is good! I posted the additional instructions in there just in case you needed them. Quote Link to comment Share on other sites More sharing options...
Oranga Posted October 1, 2018 Report Share Posted October 1, 2018 I'm in the same boat, the mirror turn signal got caught on the garage while backing out and the clear plastic housing broke. Light still works, but it's now exposed to the elements. Jsb2601 - were you able to successfully do the install? WWWPerfA_ZN0W - thanks for the extra steps, do you have a diagram of how everything goes together? The only thing i've found is this: https://www.tascaparts.com/oem-parts/ford-signal-lamp-ft4z13b374a/?c=Zz1ib2R5JnM9b3V0c2lkZS1taXJyb3JzJmk9TVMxNTYxMDUmcj02JmE9Zm9yZCZvPWVkZ2UmeT0yMDE3JnQ9c2VsJmU9My01bC12Ni1nYXM%3D which is not particularly helpful. I also plan on buying the part at that link, is ~$55 a good price for the part? Quote Link to comment Share on other sites More sharing options...
omar302 Posted October 1, 2018 Report Share Posted October 1, 2018 Service Manual procedure attached. Exterior Mirror RI.pdfFetching info... 2 Quote Link to comment Share on other sites More sharing options...
Oranga Posted October 1, 2018 Report Share Posted October 1, 2018 That is awesome, thank you omar302! Quote Link to comment Share on other sites More sharing options...
omar302 Posted October 2, 2018 Report Share Posted October 2, 2018 Credit goes to @Macbwt and his website. 2 Quote Link to comment Share on other sites More sharing options...
Jsb2601 Posted October 14, 2018 Author Report Share Posted October 14, 2018 @omar302 were you able to replace the turn signal you got from tasca? Quote Link to comment Share on other sites More sharing options...
omar302 Posted October 14, 2018 Report Share Posted October 14, 2018 @Jsb2601 I didn't require it. @Oranga did. Quote Link to comment Share on other sites More sharing options...
Jsb2601 Posted October 14, 2018 Author Report Share Posted October 14, 2018 @oranga any luck? Quote Link to comment Share on other sites More sharing options...
Digital Edge Sport Posted May 14, 2020 Report Share Posted May 14, 2020 (edited) Is this exactly the same for the 2016, I notice that the service manual is for a 2015 edge? I need to replace both of mine and didn't know if popping off the covers is easier than removing the glass and all that. Any help is appreciated Edited May 14, 2020 by Digital Edge Sport Quote Link to comment Share on other sites More sharing options...
Mike74 Posted December 30, 2020 Report Share Posted December 30, 2020 I found this information and I'm interested in the removal/reinstall of the turn signal. I have tried to remove the turn signal and what I see is a snap retainer on the left (standing in front of looking back at the mirror). I un-snapped this and tried to lift the turn signal up but seems to be something holding down. So, any suggestions? (I have to replace the turn signal and mirror cap, now waiting on parts). Thanks, Mike74 Quote Link to comment Share on other sites More sharing options...
ChasingStyx Posted June 3, 2021 Report Share Posted June 3, 2021 On 12/30/2020 at 8:04 PM, Mike74 said: I found this information and I'm interested in the removal/reinstall of the turn signal. I have tried to remove the turn signal and what I see is a snap retainer on the left (standing in front of looking back at the mirror). I un-snapped this and tried to lift the turn signal up but seems to be something holding down. So, any suggestions? (I have to replace the turn signal and mirror cap, now waiting on parts). Thanks, Mike74 Expand Curious if anyone was able to get this done? I need to replace the turn signal before lease turn in on my wife's 2018 Edge (she picked up a 19 Edge Titanium to replace it) Quote Link to comment Share on other sites More sharing options...
