Add factory sub to 2018 9 speaker factory system
Quick question, does anyone know how easy/feasible it would be to add the original factory sub to the original 9-speaker system on the SE (with option 201A). I'm no audiophile but the system is really lacking in bass, but at the same time I don't want to mess around with custom boxes, amplifiers etc. I just want an easy way to add a bit of bass. The 9 speaker system on the 2018 is woefully under-documented IMHO.
Thanks
- Tim
Non amplified systems run the speakers to the ACM (in the center stack) while the amplified systems run the speakers to the amp in the back. So you would have to re-run all the speaker wiring, along with adding the wiring for the amp including can bus lines etc. Then there is re-programming the vehicle for the amp system.
Probably easier just to install something aftermarket and it would end up sounding better anyway.
