sgkukov Posted August 3, 2018 Report Share Posted August 3, 2018 Hi, I know this must've been asked but i unfortunately can't find a direct answer on this. I have the 20" chrome wheels on my edge i purchased used. 3 of the wheels have bends in them that are causing vibrations in the body and steering wheel. I found a set of 18" 2015 Mustang GT wheel take off for low money. I'd like to get these but i can't find out if the center bore is the same. I think the off set isn't too far out so that shouldnt be a problem. Anyone do this on their car or know if it will work? Quote Link to comment Share on other sites More sharing options...
sgkukov Posted August 3, 2018 Author Report Share Posted August 3, 2018 (edited) Ok so found out the 2015 Mustang has a 70.5mm center bore 17x7.5, 18x8, 19x8.5, 19x9, 20x9 5"x114.3mm (5"x4.5") M14x1.5 70.5mm 35-52.5mm 22 inc I think ive read that the 2013 edge has a 63.44mm center bore... so this creates a problem.... https://www.wheel-size.com/size/ford/edge/2013/ Looks like the 2010 and under edge would have the same center bore as the Moostangs.... dammit. Edited August 3, 2018 by sgkukov Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted August 3, 2018 Report Share Posted August 3, 2018 Correct, 2007-10 Edge have the 70.6 mm center bore. Quote Link to comment Share on other sites More sharing options...
sgkukov Posted August 3, 2018 Author Report Share Posted August 3, 2018 the wheels are lug centric... so a larger bore on the wheel should be fine then right? Quote Link to comment Share on other sites More sharing options...
dolsen Posted August 3, 2018 Report Share Posted August 3, 2018 If it has a larger bore, I would think its ok, hard to tell without seeing it. I would be more worried about the bolt pattern. Are those the same? Quote Link to comment Share on other sites More sharing options...
sgkukov Posted August 3, 2018 Author Report Share Posted August 3, 2018 If it has a larger bore, I would think its ok, hard to tell without seeing it. I would be more worried about the bolt pattern. Are those the same? yes, the 2015 mustang still uses the 5 x 114.3 .... unlike the edge which saw the need to change the damn bolt pattern Quote Link to comment Share on other sites More sharing options...
2FAST4U Posted August 4, 2018 Report Share Posted August 4, 2018 (edited) yes, the 2015 mustang still uses the 5 x 114.3 .... unlike the edge which saw the need to change the damn bolt pattern Starting with the 2015 model year, the bolt pattern on the Edge changed from 5 X 114.3 to 5 x 108 Claude. Edited August 4, 2018 by 2FAST4U Quote Link to comment Share on other sites More sharing options...
sgkukov Posted August 4, 2018 Author Report Share Posted August 4, 2018 Starting with the 2015 model year, the bolt pattern on the Edge changed from 5 X 114.3 to 5 x 108 Claude. yup.... just said that. they changed the bolt pattern. i know these things happen but it would have been nice to have more year options. can anyone tell me with certainty... using a larger bore wheel on a smaller bore hub is fine right? The wheels are lug centric meaning a larger bore wouldnt cause any problems Quote Link to comment Share on other sites More sharing options...
