2015 Mustang wheels on a 2013 Edge
sgkukov
Hi,
I know this must've been asked but i unfortunately can't find a direct answer on this. I have the 20" chrome wheels on my edge i purchased used. 3 of the wheels have bends in them that are causing vibrations in the body and steering wheel.
I found a set of 18" 2015 Mustang GT wheel take off for low money. I'd like to get these but i can't find out if the center bore is the same. I think the off set isn't too far out so that shouldnt be a problem.
Anyone do this on their car or know if it will work?
Ok so found out the 2015 Mustang has a 70.5mm center bore
17x7.5, 18x8, 19x8.5, 19x9, 20x9​ 5"x114.3mm (5"x4.5")​ M14x1.5​ 70.5​mm 35-52.5mm 22 inc
I think ive read that the 2013 edge has a 63.44mm center bore... so this creates a problem....
https://www.wheel-size.com/size/ford/edge/2013/
Looks like the 2010 and under edge would have the same center bore as the Moostangs.... dammit.
Edited by sgkukov
If it has a larger bore, I would think its ok, hard to tell without seeing it. I would be more worried about the bolt pattern. Are those the same?
yes, the 2015 mustang still uses the 5 x 114.3 .... unlike the edge which saw the need to change the damn bolt pattern
Starting with the 2015 model year, the bolt pattern on the Edge changed from 5 X 114.3 to 5 x 108
Claude.
Edited by 2FAST4U
Claude.
yup.... just said that. they changed the bolt pattern. i know these things happen but it would have been nice to have more year options.
can anyone tell me with certainty... using a larger bore wheel on a smaller bore hub is fine right? The wheels are lug centric meaning a larger bore wouldnt cause any problems
