rwf78155 Posted August 3, 2018 Report Share Posted August 3, 2018 Before winter arrives Im looking at adding a Ford Remote Start to my 2017 Edge Sport Got a call today from dealer who was ordering the module...... Now they are telling my I need new key fobs and another module. Ive read that It is a simple plug in by Ford and just requires the current key fob to be pressed three times to activate and start the vehicle Has anyone done this and if so, tell me what parts Ill need. Quote Link to comment Share on other sites More sharing options...
jmr061 Posted August 3, 2018 Report Share Posted August 3, 2018 The description of three times of the lock button with a Ford accessory install only applies to the 2018 and up. 1 Quote Link to comment Share on other sites More sharing options...
chefduane Posted August 3, 2018 Report Share Posted August 3, 2018 My '11 had remote start and a 5 button FOB. Unless there is a different key sequence that other FOBs use, you'll need a FOB that has the Remote Start button on it. Press it twice and the car starts. Others may chime in and correct me on this but I do think you'll need a different FOB. 1 Quote Link to comment Share on other sites More sharing options...
jmr061 Posted August 3, 2018 Report Share Posted August 3, 2018 The 11-14 are not the same as 15+ in regards to KE/RS. 2 Quote Link to comment Share on other sites More sharing options...
rwf78155 Posted August 3, 2018 Author Report Share Posted August 3, 2018 So If I need to buy two new fobs and have them programmed that'll be as much as the remote start module itself. That would negate me trying to add remote start ! Thanks all btw...it's a late 2017 so that's throwing confusion for the dealership. They got the vin# and are contacting Ford Quote Link to comment Share on other sites More sharing options...
jmr061 Posted August 3, 2018 Report Share Posted August 3, 2018 (edited) I wish someone local to me would avail themselves to allow me to test a theory...but I think you can add factory build remote start by changing some hardware and reprogramming along with getting the proper fobs. Just a theory until I can try it though. I have had this theory for a long time. Edited August 3, 2018 by jmr061 2 Quote Link to comment Share on other sites More sharing options...
onyxbfly Posted August 3, 2018 Report Share Posted August 3, 2018 On 8/3/2018 at 5:00 PM, rwf78155 said: So If I need to buy two new fobs and have them programmed that'll be as much as the remote start module itself. That would negate me trying to add remote start ! Thanks all btw...it's a late 2017 so that's throwing confusion for the dealership. They got the vin# and are contacting Ford You have two options for remote start. You can use smartlink and remote start via phone. Or you can purchase the VSS and the antennae for your car. Programming the keys takes around 10-15 min but they will charge you a half an hour. I'd suggest shopping online for a 5 button or 4 button key (depending on if you have power trunk etc. You can use the keys from the edge, fusion, explorer or F150. They are infinitely cheaper online as opposed to the dealership. The saving grace is that most dealerships will cut your keys for free if you get them programmed there. Or you can program them yourself if you have two master keys. On 8/3/2018 at 8:27 PM, jmr061 said: I wish someone local to me would avail themselves to allow me to test a theory...but I think you can add factory build remote start by changing some hardware and reprogramming along with getting the proper fobs. Just a theory until I can try it though. I have had this theory for a long time. I agree with you, I thought the programming for remote start required IDS and can not be done via forscan, Quote Link to comment Share on other sites More sharing options...
vega Posted August 3, 2018 Report Share Posted August 3, 2018 (edited) On 8/3/2018 at 3:09 AM, jmr061 said: The description of three times of the lock button with a Ford accessory install only applies to the 2018 and up. Sorry, but third party remote starters are available that use three press start with original fobs or 2015 on up. I bought mine on ebay and for 125.00 dollars and installed it in about 20 minutes with no splicing, plug and play. Examples: https://www.ebay.com/sch/sis.html?_nkw=2015-18+F150+14-17+FUSION+14-17+MKZ+15-17+EDGE+PLUG+%26+PLAY+REMOTE+START+STARTER+&_id=122475959209&&_trksid=p2057872.m2749.l2658 Edited August 3, 2018 by vega 1 Quote Link to comment Share on other sites More sharing options...
jmr061 Posted August 3, 2018 Report Share Posted August 3, 2018 On 8/3/2018 at 9:32 PM, vega said: Sorry, but third party remote starters are available that use three press start with original fobs or 2015 on up. I bought mine on ebay and for 125.00 dollars and installed it in about 20 minutes with no splicing, plug and play. Sorry but I was referencing official Ford accessory hardware. Not 3rd party. 3 Quote Link to comment Share on other sites More sharing options...
rwf78155 Posted August 4, 2018 Author Report Share Posted August 4, 2018 jmr061 Can I get the Ford part number from you ? Quote Link to comment Share on other sites More sharing options...
jmr061 Posted August 4, 2018 Report Share Posted August 4, 2018 On 8/4/2018 at 2:05 AM, rwf78155 said: jmr061 Can I get the Ford part number from you ? For what exactly? Quote Link to comment Share on other sites More sharing options...
onyxbfly Posted August 4, 2018 Report Share Posted August 4, 2018 (edited) On 8/4/2018 at 2:05 AM, rwf78155 said: jmr061 Can I get the Ford part number from you ? Here is all the info you need except for the keys. You need the hood switch kit and the VSS and the Antenna https://accessories.ford.com/electronics/remote-start.html Key info (just for example) https://www.amazon.com/Ford-Keyless-Remote-5-Button-Proximity/dp/B013F4AKBQ I have this key for my 2017 https://www.amazon.com/Ford-5-Button-Smart-Proximity-M3N-A2C93142600/dp/B076TDYV2P/ref=sr_1_cc_2?s=aps&ie=UTF8&qid=1533359033&vehicle=2018-54-2816-------------0&sr=1-2-catcorr&ymm=2018%3Aford%3Afusion&keywords=2018+fusion+key+fob You need the hood switch kit and the VSS and the Antenae Edited August 4, 2018 by onyxbfly 1 Quote Link to comment Share on other sites More sharing options...
jmr061 Posted August 5, 2018 Report Share Posted August 5, 2018 (edited) BTW I stand corrected on the OEM 18+ Ford Remote Start add on. The key press squence is lock/unlock/lock, not lock 3 times. I see one dealer on eBay sells the 18 kit stating it works on all 15 and up Edges. This contradicts what the official Ford accessory site lists as far as compatibility goes. They say it is 18+ only. The Edge uses the same kit as the Explorer and I am aware of someone that had that eBay dealer send them the 18 kit for his 16 or 17 (don't remember which it was) and it caused the cluster to go nuts with errors. They ended up sending the "correct" kit and the vehicle was just fine with it. The add on accessory for the 15-17 uses a single button fob so you end up carrying two (the original and the remote start fob). This is why some people hate these kits. For the Ford authorized remote start (one way long range) this is what the kit is: https://www.ebay.com/itm/15-thru-17-Edge-OEM-Genuine-Ford-Parts-Remote-Start-Security-System-Kit-NEW/181889067427?fits=Make%3AFord%7CModel%3AEdge&hash=item2a596ee9a3%3Ag%3AtowAAOSwk-1Z94eb&_sacat=0&_nkw=ford+remote+start+edge+oem&_from=R40&rt=nc&_trksid=p2380057.m570.l1313.TR6.TRC0.A0.H0.Xford+remote+start+edge+oem.TRS0 If the vehicle already has the perimeter alarm on the window sticker it already has a functioning hood switch (built into the hood latch assembly for the 15+). Just need the kit and remote start properly enabled. Edited August 5, 2018 by jmr061 2 Quote Link to comment Share on other sites More sharing options...
AntDeek Posted August 5, 2018 Report Share Posted August 5, 2018 Side note: I have successfully added Remote Start to my 2013 SE and installed the upgraded antenna for 100ft range. If anyone has Forscan questions or any questions let me know! 4 Quote Link to comment Share on other sites More sharing options...
munchkin Posted September 8, 2018 Report Share Posted September 8, 2018 AntDeek - I have a 2017 and Im trying to add remote start but want to use the factory key fobs. Everything Ive read says I need forscan to reprogram the suv to have the hood pin activated. By dh downloaded forscan but were trying to figure out what exactly to do in the program to tell the suv to activate he hood pin. Would you happen to know? Quote Link to comment Share on other sites More sharing options...
JWH14580 Posted June 10, 2019 Report Share Posted June 10, 2019 I used an aftermarket solution on my 2017 F150, and just removed it today in anticipation of trading for an 18 Edge Quote Link to comment Share on other sites More sharing options...
