Timing Procedure?
jlchoitz
Long story short, my 2007 Edge is out of time. The engine is not damaged. I have been unable to find a timing procedure thus far. My water pump was leaking, while I was turning over the engine to align the timing marks before locking the cams, the water pump broke allowing the chain to jump and get things out of time. I dont think its by much, but I need to get it back in time.
It doesn't matter if it's just the crank or the cams - timing involves synchronizing the position of them together. From photos I've seen and articles I've read, the crank gear will have the key at the 11:00 position when at TDC of cylinder #1 but there doesn't appear to be an equivalent manual position guide for the cam gears.
  • 2 months later...
