Help with Sync 3 APIM settings for 2012 SEL
Hey All,
Much like a lot of you I just took the plunge and updated MFT to Sync 3 in my 2012 SEL. Its a super easy change to swap out the units, and I've got it mostly working thanks to all the resources on this forum!
I am having issues getting the last few APIM settings right and need some help... My biggest issue is that my clock is not working/saving time and the sync3 and dashboard times are not right. I am also having an issue with getting the ambient lighting to change, I see the option in Sync 3 but the controls don't actually do anything :cry:.
I've been using these two spreadsheets for the Explorer and F150 to help figure out what values to change, but I must be missing something...
https://www.icloud.com/numbers/0AtiYU-yJ4Nrfyfuzp-Mi0l8A#FORScan_2011-2018_Explorers
https://docs.google.com/spreadsheets/d/1uDSQ1Z5a2Wt8-kjrSiVSlDFGFHnfeuhb3RTMVz95730/edit#gid=0
Can anyone help? Having a working clock is important!
This is what I have come up with so far...
7D0-01-01 2229 9002 21D5 //needed to set these to 9 or my voice/phone button on steering wheel wouldn't work...
7D0-01-02 0283 0200 0A69
7D0-02-01 5553 0004 0086
7D0-02-02 0200 8800 0065
7D0-02-03 0000 DC
7D0-03-01 014E 3402 0060
7D0-04-01 0103 0300 09EC
7D0-04-02 0001 DE
7D0-05-01 1BA3 1B9B 2B7C
7D0-05-02 C5A3
7D0-06-01 805E
7D0-07-01 0800 3300 001A
7D0-07-02 0000 186A 0062
7D0-07-03 0056 5685 0012
7D0-07-04 7052
It's been awhile, since I tinkered, but here's my final program. Your steering wheel should work with these settings as should your Ambient light.
7D0-01-01 2A21 0002 0127
7D0-01-02 0283 0006 0A6F
7D0-02-01 5753 0B04 C0D3 - If you change 5553 to 5753 you can enter addresses while moving, but, you will lose 911 assist.
7D0-02-02 8240 8000 005D
7D0-02-03 0005 E1
7D0-03-01 0100 0002 00DE
7D0-04-01 0100 0300 09E9
7D0-04-02 0001 DE
7D0-05-02 C5A3
7D0-06-01 805E
7D0-07-03 0056 5686 0013
7D0-07-04 7052
I would keep 7D0-04-01 through 7D0-07-04 alone. Although our vehicles seem very close.
I am curious though, if you plug in a USB or use a BT device with music, do you see it on the right hand side IPC panel under entertainment options? I think the firmware on our IPC is too low, so it cannot recognize devices connected through the new APIM and USB hub.
Thanks!
I've been playing with this some more today and manged to get the clock to work, using a combination of what you provided and I had.
I haven't had a chance to see if ambient lighting is working yet, but getting the clock going is a good start.
I have the same problem as you with the audio sources, I only see Sirius, AM, FM, and CD under the IPC options. It doesn't give BT as an option, it also doesn't update if I play anything over android auto and still shows the radio information which is weird.
Maybe this is normal for Sync 3 but did they remove the favorite phone contacts? I don't see that listed as an option under the IPC either.
This is what I have right now.
7D0-01-01 2A21 8002 01A7
7D0-01-02 0083 0200 0A69 //I tried 008B in the past and it didn't work either
7D0-02-01 5553 0B04 40D1
7D0-02-03 0000 DC
7D0-03-01 014E 3002 005C
7D0-04-02 0001 DE
7D0-05-02 C5A3
7D0-06-01 805E
7D0-07-04 7052
Just to close the loop on this, I think the settings above are going to be my final settings. Everything is working now. I even noticed that even though i can't select Bluetooth audio from the IPC, it will now show the song info if i back off the entertainment menu and go back.
Thanks all for the help.
Correct. All the items will display in the IPC once theyre playing, however you can only select BT or USB species from the sync 3 screen itself. Radio, satellite and CD can still be selected from the IPC. Its because the firmware of the IPC is too low to recognize sync 3 impute (cd, radio and XM are part of the ACM and therefore unaffected).
No big deal as the hassle for updating firmware is not worth the effort (plus theres no guarantee it would work).
Glad the clock worked. Let me know if ambient light is working again. Id i remember, I had to turn it on from within sync menu the very first time and havent touched it since.
Yeah I don't know if i want to mess with trying to update the FW on the IPC, its pretty usable as is.
I think the ambient lighting was always working... I was just trying to change it when the door was open, which I guess you can't do. Shows how much I use it :) .
At some point I just need to get the new USB hub and then I should be 100% done. Overall its a pretty easy change, and I am liking it so far.
