mustang84 Posted July 18, 2018 Report Share Posted July 18, 2018 (edited) My wife and I purchased a 2017 Edge Titanium 2.0 AWD a few months ago. It had about 19,000 miles at the time of purchase and now has about 21,000 miles. Starting a few weeks after purchase, it would occasionally make a "thud" or "clunk" noise a few seconds after reversing when you start turning the steering wheel (such as backing out of a driveway or parking space). The first time it happened we thought we ran over something. It's not a violent jerk--a moderate thud is probably the best description. It only happened occasionally, but the last week or so it has been happening more frequently. Tonight as I was backing out of our driveway it made the thud twice during the same turn. When we back out of our driveway we are always turning the wheel counterclockwise, but I am not sure if that makes a difference when the thud occurs. We've tried to recreate it a couple times when I was standing outside listening, but unfortunately it always seems to happen when we're not expecting it so I haven't been able to pinpoint where exactly it sounds like it is coming from. But when inside the vehicle, it feels like it is coming form the rear. Has anyone had this issue before, and do you know what may be causing it? Edited July 18, 2018 by mustang84 Quote Link to comment Share on other sites More sharing options...
akirby Posted July 18, 2018 Report Share Posted July 18, 2018 First thought would be the rear differential/axle shaft binding. Go to an open parking lot, put it in reverse and turn the wheel sharply. Try it in both directions. When you turn the wheel counter clockwise the right rear wheel will be traveling faster than the left rear. If it only happens in one direction I would suspect the outside wheel shaft and/or differential. 1 Quote Link to comment Share on other sites More sharing options...
akirby Posted July 18, 2018 Report Share Posted July 18, 2018 Make that an EMPTY open parking lot with no obstructions......just to be safe. 1 Quote Link to comment Share on other sites More sharing options...
mustang84 Posted July 19, 2018 Author Report Share Posted July 19, 2018 First thought would be the rear differential/axle shaft binding. Go to an open parking lot, put it in reverse and turn the wheel sharply. Try it in both directions. When you turn the wheel counter clockwise the right rear wheel will be traveling faster than the left rear. If it only happens in one direction I would suspect the outside wheel shaft and/or differential. Thanks for the info. I didn't get a chance to look into it tonight, but hopefully in the next few days I can take it out and test to see if I can recreate it. Quote Link to comment Share on other sites More sharing options...
gpliowa Posted September 21, 2018 Report Share Posted September 21, 2018 Hello, I have a 2017 Lincoln MKX which I bought new and it has the AWD. I am quite sure the design is the same for both the Edge and the MKX. My car thus far made about 12 of these clunks so far and I have 20,000 miles on the car and just over a year of driving. When I back up about 5 to 10 feet, you sometimes get that clang. First time I noticed the clunk was at 15,000 miles. I researched it and find that it is a also a common issue with many manufactures other than Ford for AWD vehicles. It appears that the noise is when the friction disks which engage and lock when you are going forward so more power is directed to the rear axle. When you back up, it unwinds the driveline and then it released locking device then the gears in the rear axle clang, only once. There seems to be no answer to the issue and is a common issue for many different manufactures. I am planning to live with the issue since it is near impossible to duplicate at the dealership and seems like it is an inherent characteristic of AWD vehicles. Are you still having the issue or did you get it resolved? I am also in Iowa. Quote Link to comment Share on other sites More sharing options...
pencil8 Posted September 25, 2018 Report Share Posted September 25, 2018 I have the exact issue with my 2017 SEL....9000miles. The dealer identified it as a rear end clutch(?) problem....parts on back order. It has been over 40 days at the dealer waiting for parts. Appears to be an ongoing problem requiring a design change. Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted September 25, 2018 Report Share Posted September 25, 2018 My 98 Sable started doing this when I backed out of the garage after sitting all night. Turned out to be one (or both) rear brakes hanging the releasing. Some part needed to be greased. 1 Quote Link to comment Share on other sites More sharing options...
Kbs71 Posted November 14, 2018 Report Share Posted November 14, 2018 Just had this repaired on my 2015 Fusion. It’s the PTO clutch. Go have it fixed before it desinigrates it could leave you stranded. 1 Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted November 14, 2018 Report Share Posted November 14, 2018 You mean the RDU, Kbs? Quote Link to comment Share on other sites More sharing options...
