edgemaster Posted July 11, 2018 Report Share Posted July 11, 2018 Can someone tell me how to remove the driver seat cushion of a 2009 Edge without damaging it? I need to grease the power seat hardware. Thanks, Ed 1 Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted July 11, 2018 Report Share Posted July 11, 2018 (edited) Seat Cushion — Front Removal NOTE: The air bag warning indicator illuminates when the correct Restraints Control Module (RCM) fuse is removed and the ignition switch is ON. NOTE: The Supplemental Restraint System (SRS) must be fully operational and free of faults before releasing the vehicle to the customer. ° Remove the front seat. For additional information, refer to Seat — Front in this section. ° Release all wire harness and connector retainers to the cushion frame. ° For seat with fold-flat backrest, separate the fold-flat recliner cable holders from the bottom of the cushion frame. ° If equipped, disconnect the cushion Thermo-Electric Device (TED) electrical connector. ° If equipped, disconnect the heated seat module and 2 heater mat electrical connectors. ° Separate the pin-type retainers from the cushion frame. ° Remove the 4 cushion frame-to-seat track bolts and cushion assembly. Installation For seat with fold-flat backrest, make sure the fold-flat recliner cable is routed correctly between the power seat track cross tube and cushion frame. ----------------------- Position the cushion assembly and install the 4 cushion frame-to-seat track bolts. For power seat track, make sure the cushion frame-to-seat track rear brackets are aligned correctly with the tabs seated in the cushion frame. Tighten to 23 Nm (17 lb-ft). For correct front passenger seat cushion wire harness routing, refer to Seat Wire Harness Routing — Front Passenger Cushion in this section. For seat with fold-flat backrest, attach the 2 fold-flat recliner cable holders to the bottom of the cushion frame. Connect the heated seat module 2 heater mat electrical connectors. Route the wiring harnesses and attach the pin-type retainers to the cushion frame. If equipped, connect the cushion TED electrical connector. Attach any remaining wire harness and connector retainers to the cushion frame. ---------------- All seats ° Remove the front seat cushion. (above) For additional information, refer to Seat Cushion — Front in this section. ° Release the cushion trim cover retainers from the cushion frame and remove the cushion trim cover and cushion foam pad. NOTICE: Use care when separating the cushion trim cover from the hook-and-loop strips, or the hook-and-loop strips can be torn from the cushion foam pad. NOTE: A new heater mat will come assembled on a new foam pad. ° Remove the cushion trim cover from the cushion foam pad in the following sequence. ° Separate the hook-and-loop strips. ° Separate the cushion trim cover wire retainer from the clips in the cushion foam pad. ° For vehicles with climate controlled seat, on assembly make sure the climate control seat manifold is in place before snapping the cushion trim cover wire retainer back into the cushion foam pad. Install the front seat. For additional information, refer to Seat — Front in this section. ° Position the cushion assembly and install the 4 cushion frame-to-seat track bolts. ° For power seat track, make sure the cushion frame-to-seat track rear brackets are aligned correctly with the tabs seated in the cushion frame. ° Tighten to 23 Nm (17 lb-ft). ° For correct front passenger seat cushion wire harness routing, refer to Seat Wire Harness Routing — Front Passenger Cushion in this section. ° For seat with fold-flat backrest, attach the 2 fold-flat recliner cable holders to the bottom of the cushion frame. ° Connect the heated seat module 2 heater mat electrical connectors. ° Route the wiring harnesses and attach the pin-type retainers to the cushion frame. ° If equipped, connect the cushion TED electrical connector. ° Attach any remaining wire harness and connector retainers to the cushion frame. ° Install the front seat. For additional information, refer to Seat — Front in this section. ----------------------------------------------- ° Remove the front seat cushion. {above} For additional information, refer to Seat Cushion — Front in this section. ° Release the cushion trim cover retainers from the cushion frame and remove the cushion trim cover and cushion foam pad. ° NOTICE: Use care when separating the cushion trim cover from the hook-and-loop strips, or the hook-and-loop strips can be torn from the cushion foam pad. NOTE: A new heater mat will come assembled on a new foam pad. ° Remove the cushion trim cover from the cushion foam pad in the following sequence. ° Separate the hook-and-loop strips. ° Separate the cushion trim cover wire retainer from the clips in the cushion foam pad. ° For vehicles with climate controlled seat, on assembly make sure the climate control seat manifold is in place before snapping the cushion trim cover wire retainer back into the cushion foam pad. Item Part Number Description 1 62901 Cushion trim cover 2 18D507 Cushion climate control seat manifold (**) 3 632A23 Cushion foam pad 4 — Cushion heater mat (part of 632A23) 5 63226 Cushion support 6 W505945 Cushion Thermo-Electric Device (TED)-to-climate control seat cushion adapter screw (**) 7 18D507 Cushion TED adapter (**) 8 63100 Cushion frame 9 62294 Recliner side shield screw 10 W714053 Scrivet 11 62187 Recliner side shield 12 — Safety belt buckle-to-seat track nut (part of 61203) 13 61203 Safety belt buckle 14 18D507 Cushion TED (if equipped) 15 W505945 Cushion TED -to-cushion frame screw (3 required) (**) 16 — Screw grommet (3 required) 17 60328 Cushion frame-to-seat track rear brackets 18 14A163 Wire clip 19 14A699 Driver seat wire harness 20 19E880 Cushion TED filter (if equipped) 21 W506021 Seat track-to-cushion frame bolts (4 required) 22 61711 Power seat track assembly 23 14B416 Seat position sensor (driver only) 24 62294 Seat track cover retainer 25 62187 Seat track cover 26 14A701 Seat control switch 27 62187 Cushion side shield 28 62294 Cushion side shield retainer (3 required) 29 14711 Power lumbar switch knob (**) 30 14711 Power seat recliner knob 31 14711 Seat control switch knob 32 14C708 Driver Seat Module (DSM) (**) 33 62294 DSM -to-bracket screw (2 required) (**) 34 62294 Bracket-to-seat track screws (**) 35 14A301 DSM bracket (**) 36 14A301 Shield bracket 37 62294 Shield bracket screws (**) = (if equipped) Edited July 11, 2018 by enigma-2 2 Quote Link to comment Share on other sites More sharing options...
edgemaster Posted July 12, 2018 Author Report Share Posted July 12, 2018 Holy Moly, Looks like this is not a diy job. Thanks anyway. Ed Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted July 12, 2018 Report Share Posted July 12, 2018 I used WD40 dry lube and sorated the hell out of everything I could see. Getting under the seat to spray the inside rail is a pain. 1 Quote Link to comment Share on other sites More sharing options...
edgemaster Posted July 16, 2018 Author Report Share Posted July 16, 2018 So, you just sprayed from the under site without removing the seat cushion? Doesn't that stuff drip all over the carpet for days and smell awful? Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted July 16, 2018 Report Share Posted July 16, 2018 WD40 dry lube is different than WD40. (I just sprayed the tracks as best I could.) Quote Link to comment Share on other sites More sharing options...
edgemaster Posted July 16, 2018 Author Report Share Posted July 16, 2018 OK, didn't know about the dry lube stuff. Sounds like the way to go. Thanks a lot. Ed Quote Link to comment Share on other sites More sharing options...
edgemaster Posted July 17, 2018 Author Report Share Posted July 17, 2018 What about spraying the connectors inadvertently? Would that screw up the electrics under the seat? Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted July 17, 2018 Report Share Posted July 17, 2018 OK, didn't know about the dry lube stuff. Sounds like the way to go. Thanks a lot. Ed This is what I used: WD-40 Specialist Dirt & Dust Resistant Dry Lube PTFE Spray with SMART STRAW SPRAYS 2 WAYS, 10 OZ https://www.amazon.com/dp/B00AF0ODGM/ref=cm_sw_r_cp_apa_T.ItBbAJHKTH7 Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted July 17, 2018 Report Share Posted July 17, 2018 What about spraying the connectors inadvertently? Would that screw up the electrics under the seat? Unlikely imo. The connectors are tight and not subject to moisture intrusion. I hit the tracks from front and rear, sprayed as much as I could reach. Quote Link to comment Share on other sites More sharing options...
edgemaster Posted July 17, 2018 Author Report Share Posted July 17, 2018 OK, I'll check at my local ACE hardware store. Thanks again. Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted July 17, 2018 Report Share Posted July 17, 2018 FYI, I also use this on my BAMR as well. Stray makes it easy to get through the rubbers gaskets onto the tracks. Fast too. Quote Link to comment Share on other sites More sharing options...
edgemaster Posted July 17, 2018 Author Report Share Posted July 17, 2018 I had to look up BAMR. Thanks for the tip. Quote Link to comment Share on other sites More sharing options...
akirby Posted July 17, 2018 Report Share Posted July 17, 2018 I had to look up BAMR. Thanks for the tip. Interesting tidbit - that name came from the Ford engineers themselves while they were working on the first application on the first gen Edge. Quote Link to comment Share on other sites More sharing options...
