Sade2000 Posted July 9, 2018 Report Share Posted July 9, 2018 Hello Folks, after replacing my front lower controll arms, outer steering ball joints, shocks and so on (Car has 130.000 miles now), I need to do a allignment for my Edge. My Problem is, that it is an import and no shop here in Germany has the data for this car in their systems. May you can do me a favour and post the important data or a data sheet, which I can give to the shop. Thanks in advance. (and sorry for my bad english ) Grretings from Germany Dennis Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted July 11, 2018 Report Share Posted July 11, 2018 (edited) Alignment Specifications Item LH RH Total/Split Front Camber (all except GTDI) -0.05° ± -0.75° -0.55° ± -0.75° 0.5° ± 0.75° a Camber (GTDI) -0.15° ± -0.75° -0.65° ± -0.75° 0.5° ± 0.75° a Caster (all except GTDI) 4.3° ± 0.75° 4.5° ± 0.75° -0.20° ± 0.75° b Caster (GTDI) 4.4° ± 0.75° 4.6° ± 0.75° -0.20° ± 0.75° b Toe — — 0.10° ± 0.20° Rear Camber -0.45° ± 0.75° -0.45° ± 0.75° 0° ± 0.75° Thrust angle — — 0° ± 0.50° Toe +0.05° ± -0.20° +0.05° ± -0.20° 0.10° ± 0.20° a Camber Total/Split = LH Camber — RH Camberb Caster Total/Split = LH Caster — RH Caster General Specifications Item Specification Ball Joint Deflection Lower 0-0.2 mm (0-0.08 in) Ride Height Front — All Edge/MKX vehicles except GTDI 53 mm (2.086 in) ± 12 mm (0.472 in) Front — GTDI Edge/MKX vehicles 41 mm (1.614 in) ± 12 mm (0.472 in) Rear — All Edge/MKX vehicles without 22-inch wheels 127 mm (4.999 in)± 14 mm (0.551 in) Rear — GTDI Edge/MKX vehicles 113 mm (4.448 in) ± 14 mm (0.551 in) Rear — All Edge vehicles with 22-inch wheels 126 mm (4.96 in) ± 14 mm (0.551 in) Torque Specifications Description Nm lb-ft Rear camber adjustment bolts 150 111 Rear toe adjustment bolts 200 148 Stabilizer bar lower nut 90 66 Stut upper mounting plate nuts 30 22 Tie-rod jam nuts 90 66 Edited July 11, 2018 by WWWPerfA_ZN0W 2 Quote Link to comment Share on other sites More sharing options...
Sade2000 Posted July 11, 2018 Author Report Share Posted July 11, 2018 Thanks a lot, hope my wheel shop can transfer this data to my car Cheers Dennis 1 Quote Link to comment Share on other sites More sharing options...
