t0lkman Posted July 5, 2018 Report Share Posted July 5, 2018 My Edge's standard tires are 20", but I noticed the car comes with 18" spare tire. Won't it kill the AWD system in case I need to drive 50 mile on the spare tire with different size? Quote Link to comment Share on other sites More sharing options...
akirby Posted July 5, 2018 Report Share Posted July 5, 2018 Measure the circumference - it’s the same as the regular tires. Wheel size doesn’t matter - tire diameter/circumference does. Quote Link to comment Share on other sites More sharing options...
t0lkman Posted July 5, 2018 Author Report Share Posted July 5, 2018 So they put different spare tire to different trims? Quote Link to comment Share on other sites More sharing options...
omar302 Posted July 5, 2018 Report Share Posted July 5, 2018 Yes. The Spare has a different tire that is for temporary use only and max speed of 50 mph (if I remember correctly). AWD will probably disconnect when using the spare & you should revert to the original wheel/tire as soon as possible. It is mentioned in the Owenr's manual, though not in a clear section. It is under the information messages, All Wheel Drive. 2 Quote Link to comment Share on other sites More sharing options...
omar302 Posted July 6, 2018 Report Share Posted July 6, 2018 So they put different spare tire to different trims? As far as I know, the same spare is for all trims, but in the parts list there seems to be a steel & aluminum spare wheel. I don't know on what basis which is included in any trim, that is if they are even supplied differently as it could be a parts list thing and/or market dependant. My 16 Sport has the steel spare. 1 Quote Link to comment Share on other sites More sharing options...
