TSS/OSS Part Numbers
apahany
Hello,
Pardon me if this is a repeat, but I can't find it anywhere on the forum. I'm having the usual issues attributed to TSS/OSS failures and am going to replace them. However, I can't seem to locate part numbers. The OSS part was easy to find, but is there a separate TSS part or are they the same sensor?
I'm working on a 2008 Lincoln MKX.
I appreciate the help!
Being that your best bet is replacing them with FoMoCo parts, your local dealer should have the numbers.
This far into a tranny is not where you want to go cheap.
Depending on your issues, be sure to give the solenoid valve body a long, hard look. Once again, as long as you have it all apart....
Also, not to put too many thoughts into your head: http://www.fordedgeforum.com/topic/20525-2007-sel-transmission-issues/
