Randy Johnson Posted May 21, 2018 Report Share Posted May 21, 2018 Yes yes, I know everyone claims the waste gate can only be replaced by replacing the turbo. However, I want to make sure it is not the simple diagram and rod actuator that is causing my problems, has anyone attempted to just source this part on its own? Anything in the aftermarket world that could be placed in? Somedays I have zero boost, some days it is 10 PSI. I no longer get the full 16 range. Sounds like a stuck wastegate. It could the internal gate is broken, but why not try the simple external diaphragm? http://fordstnation.com/member-chad-albums-focus-st-2-0l-ecoboost-engine-picture2109-ford-focus-st-ecoboost-engine-12.html Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted May 22, 2018 Report Share Posted May 22, 2018 Any possibility that it could be an unrelated problem causing the low boost? 1 Quote Link to comment Share on other sites More sharing options...
