jimbelk Posted May 20, 2018 Report Share Posted May 20, 2018 When trying to use the remote start on my 2015 Titanium with the key Fob, I don't get a green light. I get a solid red light. I have checked and the system is enabled. It used to work but now does not. Have tried both keyfobs. Doors are locked. Don't know where to look for the hood switch. all other functions on the fobs work as they are supposed to. Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted May 20, 2018 Report Share Posted May 20, 2018 (edited) Couple of thoughts. One is you may have accidentally disabled the remote start in the info display. OM pg 108. 2nd is possibly the hood switch has failed. Test by open hood, hold down switch and try remote start. Do you get horn honks, lights? [edit] On my mkx, the hood switch is a small (1") rubber nub, front of engine compartment, passenger side. It sticks up and hood presses on it when closing. Easy to find. Edited May 20, 2018 by enigma-2 1 Quote Link to comment Share on other sites More sharing options...
omar302 Posted May 20, 2018 Report Share Posted May 20, 2018 on a 2015+, the hood switch is different. I think it is part of the hood latch. But if the the switch is acting up, you should get a hood open/ajar message in the instrument cluster. Check if you have any DTC codes. 1 Quote Link to comment Share on other sites More sharing options...
akirby Posted May 20, 2018 Report Share Posted May 20, 2018 Low battery condition will cause it not to start as well. 1 Quote Link to comment Share on other sites More sharing options...
