goslats Posted May 14, 2018 Report Share Posted May 14, 2018 Like the title says ...the wipers turned to "Off" will stay on most of the time. If we wiggle, turn to high and the off or sometimes hit the washer button and then off it will turn of, but getting worse. I'm pretty sure it's a contact in the control. Anybody have a clue as to what to do? Thanks Quote Link to comment Share on other sites More sharing options...
omar302 Posted May 15, 2018 Report Share Posted May 15, 2018 Change the wiper switch (stalk). It is quite easy & relatively cheap (~$30). This thread has good info. Search YouTube & you'll probably find a how to video. Videos for the Ford Explorer (2011-2015) are similar to the Edge. Also the procedure is similar to replacing the Turn Signal switch. 1 Quote Link to comment Share on other sites More sharing options...
goslats Posted May 15, 2018 Author Report Share Posted May 15, 2018 Thanks. That thread says it all. I cant figure out what all these tell me though. Not sure which one to look for.. Mine is a 2012 Edge SLE...I think LOL manual tilt column. Is the "speed sensitive....intermittent...variable speed? 17A553 (SW-6963) Window Wiper Switch With Manual Tilt/Slide Stg Column ; Speed Sensitive Windscreen Wipers; Black Vehicle Build Date before: 5/31/2013 17A553 (SW-6964) Window Wiper Switch With Manual Tilt/Slide Stg Column ; Rain Sensitive Windshield Wipers; Black or With Power Tilt/Telescopic Strg Column 17A553 (SW-7037) Window Wiper Switch With Manual Tilt/Slide Stg Column ; Speed Sensitive Windscreen Wipers; Black Vehicle Build Date after: 6/1/2013 Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted May 15, 2018 Report Share Posted May 15, 2018 If you have rain sensing wipers, you want SW6964. Otherwise you want SW6963. Quote Link to comment Share on other sites More sharing options...
goslats Posted May 16, 2018 Author Report Share Posted May 16, 2018 Ok....Got it Thanks! Quote Link to comment Share on other sites More sharing options...
goslats Posted May 17, 2018 Author Report Share Posted May 17, 2018 Thanks everybody. Changed it today and only took 10-15 minutes. 1 Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted May 18, 2018 Report Share Posted May 18, 2018 Let us know if it resolves the issue Quote Link to comment Share on other sites More sharing options...
goslats Posted May 21, 2018 Author Report Share Posted May 21, 2018 Oh Yeah, issue resolved. And got to say this is truly a GREAT board! I go on other boards for many DIY and other stuff, and this board does truly get to the point to help troubleshoot the problem and resolve it. Thank you folks! 1 Quote Link to comment Share on other sites More sharing options...
