Edu Posted April 28, 2018 Report Share Posted April 28, 2018 Planned to go out this morning, so i started my Ford Edge 2012 SEL and had a check charging system light on. I did a quick check and discovered that the alternator was not charging the battery. Battery voltage was 11.4v with engine running. I disconnected the voltage regulator (3 pin plug) that connects to the alternator and tested for voltage on the terminals. One terminal had voltage equal to the battery voltage but the other 2 terminals had no voltage. Any suggestions on how to solve this problem? is my alternator bad? Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted April 30, 2018 Report Share Posted April 30, 2018 any codes in the computer? about 3v too low at 2,000 rpm, and about 1.2V too low at idle. Did you check the voltage between the B+ terminal and the positive battery terminal. The test to ground at battery voltage is fine. But maybe there is a drop between the B+ terminal on the alternator to battery positive terminal connection. Also slow charge the battery overnite with a battery tender see if it holds a charge. Any electrical gremlins with the CD player, shifter or door latch? Quote Link to comment Share on other sites More sharing options...
DirtyWaters Posted December 8, 2019 Report Share Posted December 8, 2019 I am having this same problem. What solution worked for you?? Quote Link to comment Share on other sites More sharing options...
14AWD3.5 Posted February 9, 2020 Report Share Posted February 9, 2020 Shops like Goodyear and Firestone will do a charging system check, and usually apply the fee ($35) to the repairs. Quote Link to comment Share on other sites More sharing options...
